rev limiter
Old Jan 26, 2007 | 05:18 PM
Singlecam4dr's Avatar
Default rev limiter
what is rev limiter on a d15b and what will vtec engage at?
SupraRXZ's Avatar
Default Re: rev limiter (low_ef9)
depends on the ECU your using
Old Jan 26, 2007 | 05:19 PM
Default Re: rev limiter (SupraRXZ)
sorry bout that p28
Old Jan 26, 2007 | 05:41 PM
crazykamper's Avatar
while we are on the subject, what is the safetest to rev a stock d16a6, with stock ecu ect.....
Old Jan 26, 2007 | 06:35 PM
JOE BD-0's Avatar
Default Re: (crazykamper)
I think the stock D16a6 rev limiter is set at somewhere around 6800 if I'm not mistaken......good luck
Old Jan 26, 2007 | 08:56 PM
ILcrxsi1's Avatar
I tell doctors what to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by low_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">what is rev limiter on a d15b and what will vtec engage at?</TD></TR></TABLE>I have the p08 vtec engages around 4800-5000 rpm and the rev limiter is 7800. I would imagine the p28 would be similar.
Old Jan 27, 2007 | 09:57 AM
blake22's Avatar
Default Re: rev limiter (ILcrxsi1)
thanks
Old Jan 27, 2007 | 10:50 AM
how high could i rev my d16a6 safely? if i were to remove the rev limiter somehow?
Old Jan 27, 2007 | 11:31 AM
office888's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykamper &raquo;</TD></TR><TR><TD CLASS="quote">how high could i rev my d16a6 safely? if i were to remove the rev limiter somehow?</TD></TR></TABLE>
"rev safely" and "remove rev limiter" don't belong together. =P
Depends on your modifications. Remember, D-series rods are like toothpicks. The rod bolts are also extremely weak. Spun bearings become a factor with that.
I'd say keep the stock rev limiter on a stock motor unless you upgrade to ARP rods bolts and H-Beam rods (or similar).
Old Jan 27, 2007 | 11:50 AM
SIred91's Avatar
Rainman
Default Re: (office888)
The rod to stroke ratio and reciprocating mass issues must be addressed. Your redline is there for a reason.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by office888 &raquo;</TD></TR><TR><TD CLASS="quote">
I'd say keep the stock rev limiter on a stock motor unless you upgrade to ARP rods bolts and H-Beam rods (or similar). </TD></TR></TABLE>
^^ true to a point. The stock A6 is not worth anything above 7200 where the fuel cut off is. It will not make any usable power. revving that high is pointless on a stock motor, unless you are just trying to destroy it.
Even after the bottom end upgrades you still have the rod stroke ratio to worry about, It will put EXTREME pressure on the cylinder walls above the stock redline.
I am pursuing an engine build with modified stroke and piston height, I hope what I have planned will work out.
I'm still not going to rev past 7500, but I hope to make significant power gains in the stock rev range....
Syndacate
14
Mar 13, 2020 01:59 PM
severaltony
Mar 15, 2012 11:23 PM
KDvtec5757
Jul 1, 2008 07:30 AM
bruce-si
Jan 21, 2006 09:31 PM
BlackCivSi
21
May 4, 2004 08:24 PM
