90 hatchback std heater blower
well i did a search and came up with nothing i was looking for.i was wondering if i could use a 89 or 90 civic ex heater blower on my std hatch?
Should be able to, reference part numbers and see if they're different.
http://www.hondapartsdeals.com
and does anybody know what could be tha problem if my heater isnt blowing right.its set at 4 and its not blowing full blast.can someone show me a pic of the resistor switch.thanks
The resistor allows low speed opration choices. Full speed (4) is bypassing the resistor. If the blower isn't moving a lot of air on full speed, the motor is toast or there is something binding the blower wheel.
im thinkin it only works on 4 and when i hit the blower motor a little it tends to blow out a little more heat but not as much as it should.
1 2 and 3 dont seem to work.number 4 works but its not blowing full blast its only blowing a little bit of heat. any suggestions?
I had that same problem, when i disasembled it i found it had lots of crap on the blower fins. all that crap was preventing it to run any slower than on the 4 position. so try doing that, it shouldt take more than an hour to pull it out and check it.
nvm i just check today and listened to my heater carefully and all the speeds work but not at the speed they should be blowing at.the blower sometimes goes off and on. i would have to hit the blower motor to blow heat out.even if its at 4 it still blows a little bit of heat.any ideas?
Nihilus
Jan 25, 2005 10:29 PM
