D16A6 Oil Leak
Old Jan 26, 2007 | 11:51 AM
98r410's Avatar
Default D16A6 Oil Leak
I just finished by rebuild and have the engine running well but when I shut off the engine and wait a couple minutes, I have an oil leak comming from the front of the engine. It does not leak when the engine is running, only after I turn it off. It seems to be comming from the grank seal but the weird thing is it definately does not leak while running. I tested this by placing newspaper under the motor while letting it idle. This weekend I will take off the crank pulley and front cover and have a look but any ideas where its comming from? Thanks.
Old Jan 26, 2007 | 12:38 PM
dr_latino999's Avatar
Default Re: D16A6 Oil Leak (98r410)
Thoughts - Oil level is too high, hence when the engine is off and a good portion of the oil makes it back to the pan, its passing a seal. What else, at idle the leak is being picked up or blocked by a moving part, rendering it invisible.
Jeff Mizner
Dec 2, 2017 03:23 AM
bluemc
Mar 10, 2012 08:44 AM
mkgrffn
Jun 15, 2009 03:15 PM
matmcg
May 9, 2008 08:40 PM
toykicks
Apr 21, 2006 10:58 PM
