emanage harness for 91 civic
Old Jan 26, 2007 | 09:47 AM
949's Avatar
949
Default emanage harness for 91 civic
i am looking to see if there is such a thing, but i dont want to hack up my stock narness. i wanted to find a place that makes a harness so i can just plug n play greddy emanage to my 1991 d16a6 civic ecu.
thanks for any help i can get.
Modified by 949 at 11:00 AM 1/26/2007
Old Jan 26, 2007 | 10:00 AM
Creator's Avatar
Default Re: emanage harness for 91 civic (949)
you could buy a extended harness piece from xenocron.com (I think they have them)and hack into that. You just unplug your harness plug it into the jumper harness and plug that into your ECU then you have that section to cut into.
Old Jan 26, 2007 | 12:57 PM
949's Avatar
949
thanks you for the reply. i was actually wanting a premade wiring harness so i dont have to deal with that diy.
Old Jan 26, 2007 | 03:49 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (949)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 949 &raquo;</TD></TR><TR><TD CLASS="quote">thanks you for the reply. i was actually wanting a premade wiring harness so i dont have to deal with that diy. </TD></TR></TABLE>
No such thing man, its custom wiring
Old Jan 26, 2007 | 04:19 PM
949's Avatar
949
hey i just found it.
http://www.boomslang.us/emanage.htm
they said it works perfectly from boomslang. just plug n play.
anyone tried boomslang products yet?
Old Jan 26, 2007 | 05:55 PM
Deetz's Avatar
Crazy Honda Guy
^^^ wow, thats cool, i had no idea. Only thing you missed is that made to work on OBD1 systems, not your stock ecu
Modified by Deetz at 11:22 PM 1/26/2007
Old Jan 26, 2007 | 09:41 PM
949's Avatar
949
do you mean the harness or the emanage?
because i asked about the emanage from a few tuners, they all said if its wired up right the emanage will work. which the harness makes sure of that.
of course if you know for sure please enlighten me more cause i am still just learning about this. and i need all the correct info i can get.
Old Jan 27, 2007 | 06:57 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: (949)
That harness is meant for a plug and play into a car running obd1. Your car stock is obd0, and you'd need to covert to obd1 which is a better system anyway, i run it myself in my crx. For the upgrade you will need:
- obd1 distributor
- obd1 ecu (ie- p28, p30, p72)
- single 4 wire o2 sensor
The upgrade is well worth it for tuning capabilities, and giver better fuel mileage.
Old Jan 28, 2007 | 07:51 PM
949's Avatar
949
no your incorrect the harness is for obd0. i specifically asked the guy who worked at boomslang. he did say that its for the obd0.
Old Jan 29, 2007 | 05:50 AM
Deetz's Avatar
Crazy Honda Guy
If thats the case then your good to go.
Old Jan 29, 2007 | 07:23 AM
949's Avatar
949
thanks. i just wanted to triple check for this as they do want about 190.00 for the harness. i dont mind the price as long as it works.
beat ignition
Honda Civic (2001 - 2005)
Jan 5, 2019 09:13 AM
ShadowKhaN
16
May 3, 2016 11:12 AM
SlowB16
Nov 5, 2003 01:05 PM
Charlie Moua
Feb 27, 2002 06:11 PM
