ls, gsr, b16, dohc vtec cam gears all the same?
Old Jan 25, 2007 | 06:17 PM
dem0nk1d's Avatar
Default ls, gsr, b16, dohc vtec cam gears all the same?
looking to buy a set of cam gears soon when i pick up a vtec head for my ls block. just wanted to know if all b-series cam gears are the same? So if i pickup a set of adjustable for whic ever head i will get being a b16 or gsr, i will have no issuess. And in the present being able to use them on the ls motor
Old Jan 25, 2007 | 06:54 PM
BlueIntegraBoy's Avatar
Default Re: ls, gsr, b16, dohc vtec cam gears all the same? (dem0nk1d)
The b-series cam gears are all the same
Old Jan 25, 2007 | 06:57 PM
jdm_bones's Avatar
research please, this same topic was cover last week...
Old Jan 29, 2007 | 07:48 PM
siscoa36's Avatar
Default Re: ls, gsr, b16, dohc vtec cam gears all the same? (BlueIntegraBoy)
hey when you guys say that they are all the same does that mean that all the lifts are the same, or would a gsr intake lobe lift hight for long then a ls, i ask cause im have a 99 ls auto and i am going to freshen up my block cause i recently hit the 90k miles and was thinking about changing the cams and cam gears and wanted a little bit more power so will gsr cams or itr cams be better than my ls ones.
Old Jan 29, 2007 | 07:53 PM
davidluko's Avatar
Vtec cams won't fit in a non-vtec head. The OP is talking about cam gears, not cams. And 90k is still low miles for a Honda, you don't need to be 'freshening up' the block unless you're building it up for performance.
Frost7177
Mar 11, 2009 05:49 PM
gd99em1
Apr 18, 2007 04:55 PM
Ls VtEc KiD
Jan 25, 2005 08:48 PM
CBR600OnTop
Dec 31, 2002 01:42 PM
boosted hybrid
Dec 19, 2001 11:06 AM
