rocker shaft question
Old Jan 25, 2007 | 10:38 AM
nexgen91's Avatar
Default rocker shaft drilled question
I was drilling out a stuck bolt in my engine and drilled the rocker shaft and underneath it just a little (less than 1/16") Im wondering if this is alright, or will it cause any damage? also Where the CAM holders go is drilled a little more than it probably should be but not outside of the flat area (just where it would be under the holder) would this cause me any problems? thanks
Old Jan 27, 2007 | 07:47 PM
Mavrick's Avatar
Default Re: rocker shaft drilled question (nexgen91)
shouldn't cause a problem just as long as you get all the shavings out of the head when you are done. Personally I would get another rocker shaft if I was you because if you did make a problem it could really damage your engine
slo4door
Aug 21, 2007 10:39 AM
ge_itr
Feb 3, 2007 07:27 PM
slo4door
May 5, 2006 04:58 PM
DC 2
May 2, 2004 09:03 PM
