Leaking water inside......anyone??
Old Jan 25, 2007 | 08:43 AM
brandon812's Avatar
Default Leaking water inside......anyone??
I have water coming into the car...its pooling in the trunk and then leaks down under the rear seats..anyone have this prob? right now i took everything out and im going to start spraying the car down and see where it is coming from, i just thought i would ask if this has happend to anyone else???? its a 97
Old Jan 25, 2007 | 08:53 AM
kulrevon's Avatar
Default Re: Leaking water inside......anyone?? (brandon812)
Possibly tail lights. possibly the drain tubes from the sunroof. They get clogged sometimes. I would say pull out all of the trunk lining and get out a house.
Old Jan 25, 2007 | 08:55 AM
brandon812's Avatar
Default Re: Leaking water inside......anyone?? (kulrevon)
i was thinking the sunroof cause my 240sx did that but there would be ater in the front of the car from hitting the brakes....i just now got the lining off and the tail lights have some water kinda inside that housing. im going to take the tails off and put some sealant around them.
Old Jan 25, 2007 | 08:57 AM
mlow634's Avatar
This problem is common with 97-01 owners and a few threads are available on here with solutions, discussions etc. Use the search feature in the upper right hand corner and search "archived content"
Old Jan 25, 2007 | 09:20 AM
ethereal2pt2's Avatar
Default Re: Leaking water inside......anyone?? (mlow634)
not a few, COUNTLESS. i wish there was some way to force noobs to use the search button. maybe we should change it to size 1000 font and cover up the whole page.. maybe they'll use it then.
Old Jan 25, 2007 | 09:52 AM
britishdude's Avatar
Default Re: Leaking water inside......anyone?? (_BB6)
Can't the system be set, so it won't allow new members to post a thread until they have done a search, with the same procedure set for the first 14 days or 14 posts whatever comes first ? It would cut down the same old Q's being asked repeatedly because it's easier posting than searching.
Old Jan 25, 2007 | 11:30 AM
brandon812's Avatar
Default Re: Leaking water inside......anyone?? (britishdude)
well maybe a tutorial for new people to the site..... I asked a simple question and they answered it for me and yes i did find the leak. for you other **** that just posted to give me **** go suck on one cause you guys were no help.
Old Jan 25, 2007 | 05:48 PM
your tutorial, sir.
Old Jan 25, 2007 | 06:25 PM
projectchris
Guest
Posts: n/a
He asked a question, stop getting all butt hurt.
and btw, got the sameee problem!
Old Jan 25, 2007 | 06:36 PM
pprowler6's Avatar
Default Re: Leaking water inside......anyone?? (projectchris)
its ok i just started my lude for the first time in about a month from doing a tranny swap and noticed water leaking from the back after i drove it a little so i popped the trunk and there is about 2 inches of ice in the bottom...out came the hair drier
Old Jan 25, 2007 | 06:52 PM
Default Re: Leaking water inside......anyone?? (pprowler6)
the reason im being an *** is because this water leak issue has been covered numerous times. just run an archived search. you'll even find my thread on this. i have no problems if you've already searched this and done what ppl have suggested but i seriously don't think you have. until then, i'll bitch on till you do. it's called tough love.
Old Jan 26, 2007 | 08:29 AM
JDMLude850's Avatar
yeah this happens to me as well, it used to be alot worse. but i gutted out my trunk and noticed the sunroof drains werent in the drain holes, so i put them back and duct taped them cause they wouldnt stay. but there seems to be allittle water still in my trunk after it rains and as i drive it goes back there from the right side only. theres alittle stream were i can tell where i came from but i dont know where it could be coming from still? i also sprayed the whole trunk with rubberized undercoat, to dress it up alittle.
BigDaddyRich
Sep 2, 2011 11:39 AM
byronl
Sep 5, 2005 07:36 PM
oMek
Apr 19, 2004 07:29 PM
Mikey
Mar 5, 2003 04:23 PM
d8168055
Dec 6, 2001 07:52 PM
