Just some pics of our fab shop -
Old Jan 25, 2007 | 08:32 AM
david@didrace.com's Avatar
Default Just some pics of our fab shop -
- Here's one of our fabricators making some dimple die gussets for triple_s1x's STi.
- Some pictures of our sweet sheer and break.
- STi main hoop all welded up, dimple die gussets halfway done.
- Other part of our shop with a couple steel tables that we made, drill presses, old *** lathe, Mitler Bros. tubing notcher, POS Jet bandsaw.
- STi main hoop before the gussets are put on.
Old Jan 25, 2007 | 08:49 AM
triple_s1x's Avatar
Default Re: Just some pics of our fab shop - (david@didrace.com)
That kid in the red hair is sexy....
Howitt's Avatar
congrats on the clean shop
for sweeping the floor before pictures.
Old Jan 25, 2007 | 09:48 AM
Default Re: Just some pics of our fab shop - (Howitt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">congrats on the clean shop
for sweeping the floor before pictures.</TD></TR></TABLE>
It's always that clean.
Old Jan 25, 2007 | 09:56 AM
carbonall's Avatar
* B A N N E D *
Nice shop guys, how many sq ft you have?
Old Jan 25, 2007 | 10:26 AM
triple_s1x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com &raquo;</TD></TR><TR><TD CLASS="quote">
It's always that clean. </TD></TR></TABLE>
Damn right, only shop with a maid service in the midwest
Old Jan 25, 2007 | 10:48 AM
Default Re: (carbonall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonall &raquo;</TD></TR><TR><TD CLASS="quote">Nice shop guys, how many sq ft you have?</TD></TR></TABLE>
15,000 sq. ft.
All of the building below except the way back part with the closed garage door that's fenced in. We do parts installs, dyno tuning, etc. too so it's not all for fabrication.
Old Jan 25, 2007 | 02:12 PM
ssmdc2's Avatar
Default Re: (david@didrace.com)
I see you post all the time and never realized you guys were in Illinois. Where exactly are you?
Old Jan 25, 2007 | 02:21 PM
9bells's Avatar
OG Fabricator
Default Re: (ssmdc2)
Nice set-up. Cleanliness is next to ...
Old Jan 25, 2007 | 03:09 PM
743power's Avatar
Default Re: (9bells)
what series rules is that cage built for?
Old Jan 25, 2007 | 03:34 PM
Default Re: (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">what series rules is that cage built for?
It's triple_s1x's. He'll mostly be doing HPDE's this year. It's going to be a 4 point roll bar for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">I see you post all the time and never realized you guys were in Illinois. Where exactly are you?</TD></TR></TABLE>
We're located just north of Joliet.
Old Jan 25, 2007 | 03:40 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com &raquo;</TD></TR><TR><TD CLASS="quote">It's triple_s1x's. He'll mostly be doing HPDE's this year. It's going to be a 4 point roll bar for now.
cool, just fyi, nasa/scca require that diagonal to be 1 piece. Beautiful work though.
Old Jan 25, 2007 | 03:54 PM
cool, just fyi, nasa/scca require that diagonal to be 1 piece. Beautiful work though. </TD></TR></TABLE>
NASA CCR
15.6.6 Main Hoop
The main roll cage hoop should be as wide as the full width of the interior and must be as close to the roof as possible without violating CCR section #15.6.20 Inspection. One continuous length of roll bar tubing shall be used as the main hoop. The main hoop must consist of not more than four (4) bends maximum, totaling one hundred eighty (180) degrees +/- ten (10) degrees.
15.6.7 Diagonal Brace
At least one (1) diagonal brace shall be used in the same plane as the main hoop. One end of the diagonal brace shall attach to the corner, or horizontal part, of the main hoop above the driver’s head, within twelve (12) inches of the driver’s-side corner. The other end of the diagonal brace shall attach to the mounting plate (or to the main hoop as close to the mounting plate as practically possible) diagonally opposed to the driver’s head (passenger floor).
I don't believe that is true for the diagonal brace. It's mentions only that the main hoop and the halo hoop (option 2) need to be of one continuous piece of tubing.
Old Jan 25, 2007 | 04:01 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david@didrace.com &raquo;</TD></TR><TR><TD CLASS="quote">15.6.7 Diagonal Brace
I don't believe that is true for the diagonal brace. It's mentions only that the main hoop and the halo hoop (option 2) need to be of one continuous piece of tubing. </TD></TR></TABLE>
I have been researching the rules for a couple of years and I have been told it needs to be one piece. . .I guess you have to interpret the rules carefully. It specifically tells you where each of the two ends needs to attach. Your interpretation effectively gives the brace four ends.
Old Jan 25, 2007 | 04:08 PM
I have been researching the rules for a couple of years and I have been told it needs to be one piece. . .I guess you have to interpret the rules carefully. It specifically tells you where each of the two ends needs to attach. Your interpretation effectively gives the brace four ends.</TD></TR></TABLE>
Well, here are the rules for SCCA, which implies that the horizontal bar should be one piece but if it doesn't extend from the passenger side of the main hoop all the way to the driver's side that a second diagonal must be added (like if the harness bar is only for the driver's side seat).
" D. Main Roll Hoop:
1. Main roll hoop (behind the driver) shall extend the full width of the driver/passenger compartment and shall be as near the roof as possible. It shall incorporate a diagonal lateral brace to prevent lateral distortion of the hoop (See Figure 8). Any number of additional reinforcing bars are permitted within the structure of the cage. It is required that the horizontal brace behind the driver’s seat (described in Section 9.4.2.J.) continue from the diagonal to the passenger side main hoop upright or that a second diagonal be installed in the main hoop. "
Fact is I've met some people that write these rule books and they don't know what they're talking about.
Old Jan 25, 2007 | 04:35 PM
Fabman's Avatar
Lierley Fab
i think i need to start a welding school
Lamchop0000's Avatar
thats a nice place
Old Jan 25, 2007 | 04:40 PM
Default Re: (Fabman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fabman &raquo;</TD></TR><TR><TD CLASS="quote">i think i need to start a welding school </TD></TR></TABLE>
I'll tell ya what, we can use my shop and you can be the first student enrolled.
Old Jan 25, 2007 | 04:43 PM
Fabman's Avatar
Lierley Fab
you think ...nice shop...
Old Jan 25, 2007 | 05:12 PM
mynameisjustin's Avatar
Loved
Community Favorite
wow very clean shop...props to a ncie clean working environment
Old Jan 25, 2007 | 05:23 PM
Howitt's Avatar
Default Re: (mynameisjustin)
Do you own your shop? If not how much do you lease for? If so how much did it cost your to build / buy. My old 7000 SQ ft shop was 200k and just seeing how much stuff varies in the midwest
Old Jan 25, 2007 | 07:38 PM
JShull's Avatar
Man, and I feel spoiled to have a corner in my friends two car garage for my tools and welder. You guys have a nice setup.
Nice place for sure. I'll have to work my way up to that.
Old Jan 26, 2007 | 06:41 AM
Default Re: (Howitt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">Do you own your shop? If not how much do you lease for? If so how much did it cost your to build / buy. My old 7000 SQ ft shop was 200k and just seeing how much stuff varies in the midwest</TD></TR></TABLE>
My boss owns the business. We rent out the space, it's around $3000/month but my boss is friends with the owner of the building so it's a bit cheaper than it would normally be.
Old Jan 26, 2007 | 06:51 AM
Mikey3000's Avatar
looks awesome i'm jealous, i really want a machine shop.
Old Jan 26, 2007 | 06:57 AM
Howitt's Avatar
Default Re: (Mikey3000)
3000 is cheap for that space
