95 civic uses a lot of oil. quart/day
Old Jan 25, 2007 | 08:18 AM
seriot's Avatar
Default 95 civic uses a lot of oil. quart/day
I have a 95 civic ex, with stock engine. Currently im driving 250/miles a day and I have to put a quart of oil just about every morning. Im wondering because I burn through so much oil should I be bothering with an oil change at every 3000 miles seems pointless to me b/c im always putting in new oil. 2nd since im burning through this **** so much would putting some seafoam to clean the engine up a bit be a good idea?. I mean there has to be some residue left from all this oil it burns.
i think its burning so much cause i recently blew a head gasket/radiator and had it rebuilt. also have a minor O-ring leak(fixing it today).
Old Jan 25, 2007 | 08:40 AM
schardbody's Avatar
if you are burning a quart every 250 miles you will see ALOT of smoke, if you dont then you most likely have more leaks and a little blowby rather than just burning it all.
seafoam isnt going to help, if you are burning the oil the top end is oil caked already and will do it again after seafoaming, basically wasting time and money.
no point in changing the oil. fix the problem.
Old Jan 25, 2007 | 08:44 AM
CRX T-Si's Avatar
Default Re: (schardbody)
What is the milage on your engine?
What kind of oil? 10w-30, 10w40, 15w-50?
Old Jan 26, 2007 | 08:28 AM
seriot's Avatar
car has 56,000 miles on it, I use 10w-30.
Old Jan 26, 2007 | 08:36 AM
Mistermark's Avatar
do a compression and leakdown test
Old Jan 26, 2007 | 09:53 AM
AntiochOG's Avatar
Considering what you are spending on oil you should just replace your engine with another D series. It will pay for itself in no time.
Old Jan 26, 2007 | 10:01 AM
thesmogman's Avatar
Default Re: 95 civic uses a lot of oil. quart/day (seriot)
Check your PCV valve if it is stuck open it will suck the oil right out.
Actually just replace it.
Old Jan 26, 2007 | 11:05 AM
fmrprojects's Avatar
Default Re: 95 civic uses a lot of oil. quart/day (thesmogman)
sounds like it could be a leak. i had a leak on my end cam cap and it took a qt a week
blacktibby07
Feb 13, 2011 09:50 AM
Wish2345
26
Mar 23, 2010 01:47 AM
95lxcoupe
Jul 10, 2006 09:06 PM
digitalayon
Mar 13, 2005 07:55 AM
rice a roni
12
Dec 12, 2003 02:22 PM
