when i buy my bearings he said..
Old Jan 25, 2007 | 07:58 AM
q8delsol's Avatar
Default when i buy my bearings he said..
hii.
i bought my ACL mian bearings and rod bearings for my b20 from raceeng.com
the guy send to me email and say:
Thank you for your order. You did not request a thrust bearing which does
not come with any main bearing set. We can add a King thrust washer for
only $8.00. We always use this brand of thrust because it allows good crank
end play. Kindly advise as soon as possible.
Regards,
Bob
so what i should do?
Old Jan 25, 2007 | 08:09 AM
gdh8su's Avatar
Default Re: when i buy my bearings he said.. (q8delsol)
I would buy OEM Honda. I think they are $13.
Old Jan 25, 2007 | 08:18 AM
q8delsol's Avatar
Default Re: when i buy my bearings he said.. (gdh8su)
the ACL
HP MAIN BRG:B16/B18/B20 (SET)
SKU: AC-5M1959H-STD 1 $77.31
HP ROD BRG:B16/B18A&B/B20B (SET)
SKU: AC-4B1946H-STD 1 $69.07
i dont want the oem i want ACL for 600hp
so what i can do buy the king?
Old Jan 25, 2007 | 08:29 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol &raquo;</TD></TR><TR><TD CLASS="quote">
so what i can do buy the king?</TD></TR></TABLE>
I think he meant OEM thrust bearing, not the main/rod bearings.
If they recommend the aftermarket thrust bearing, go for it. Otherwise go with OEM for peace of mind.
Old Jan 25, 2007 | 08:32 AM
gdh8su's Avatar
I never had any problems with OEM thrust bearing at high HP. King is a good bearing and should do the job.
Old Jan 25, 2007 | 08:33 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by q8delsol &raquo;</TD></TR><TR><TD CLASS="quote">i dont want the oem i want ACL for 600hp
Do OEM bearings fail at that kind of power level?
Old Jan 25, 2007 | 09:31 AM
q8delsol's Avatar
Default Re: when i buy my bearings he said.. (EE_Chris)
so i think its ok with king thrust bearings for 600hp. cuz this my first tuning for high hp and should wary for everything .
thanks
Old Jan 25, 2007 | 11:35 AM
vtecspeed1320's Avatar
Shooting Star
oem honda bearings are good for 600hp no problem.
Old Jan 25, 2007 | 11:49 AM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
Do OEM bearings fail at that kind of power level?</TD></TR></TABLE>
nope. we use OEM bearings in all our block builds. We build a setup for a customer that made 920hp on his setup with OEM bearings.
Old Jan 25, 2007 | 11:57 AM
SovXietday's Avatar
Default Re: when i buy my bearings he said.. (exospeedAMcrx)
I'd go OEM over ACL any day.
Old Jan 25, 2007 | 11:58 AM
q8delsol's Avatar
its okay i will go with ACL +King THRUST
THANKS
streetsold6teeny8
Jun 1, 2010 03:02 PM
averyvm
Feb 28, 2007 08:29 PM
crxowner
Jul 23, 2006 01:22 PM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
totalimpact
Nov 11, 2003 06:39 PM
