Integra LS Rev Limiter
Old Jan 25, 2007 | 04:17 AM
7rrivera7's Avatar
Default Integra LS Rev Limiter
Just bought an LS and wanted to take it to the drag strip to see how she performs before modding her.
Can someone tell me how far I can rev her safetly becuase I think the ECU is chipped and I'm not sure if the stock limiter is still there.
Thanks!
Old Jan 25, 2007 | 04:28 AM
IntegraMastaz's Avatar
I shift at 7200Rpm Just a little bit before stock cut off. You can shift at 8000 rmp if you want but its not super safe, even 7200 is not very good if you do it all time. What I mean is if you shift all the time at 7200-8000 it aint gonna last, just depend how much your are pushing it. If you want safe shift at 3000rpm
Old Jan 25, 2007 | 04:31 AM
mike5809's Avatar
Default Re: (IntegraMastaz)
I used to shift at 8600-8750 in my DA-LS
But that was a FULLY Built motor... i forget what stock is i thought it was 6800 or around there I would of guessed?
Old Jan 25, 2007 | 06:23 AM
7rrivera7's Avatar
Default Re: Integra LS Rev Limiter (7rrivera7)
I guess I'll shift at 7k tonight...
Old Jan 25, 2007 | 06:33 AM
mike5809's Avatar
Also it really doesnt matter how "high" your car can shift, your going to want to shift when your car stops making gains in power. Now if you have a fairly stock car it is going to be before the redline. Reving up higher is just kinda pointless.
Old Jan 25, 2007 | 06:41 AM
7rrivera7's Avatar
Default Re: Integra LS Rev Limiter (mike5809)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">Also it really doesnt matter how "high" your car can shift, your going to want to shift when your car stops making gains in power. Now if you have a fairly stock car it is going to be before the redline. Reving up higher is just kinda pointless.</TD></TR></TABLE>
I understand that. Except the LS motor in in a 93 Civic hatch and the cluster redline at 7k doesn't apply to this engine. That is why I'm asking how far I should rev the stock block
Old Jan 25, 2007 | 06:43 AM
mike5809's Avatar
Gotcha! I think the 90-91 DA's were 6800, and the newer tegs were 7200. Again im not 100% im sure a search will yeild the correct answers.
good luck at the track.
Old Jan 25, 2007 | 09:14 AM
95 integra's Avatar
94+s are 6800 on the tach and 7k even on the fuel cut.
If its a stock ecu (no chip/mods/vtec controller) and it goes to 7200 or so, then its likely that the tach is off and not reading correctly (off roughly 2% or so). Either way, I found that going past about 6500 isnt really faster on a stock LS...with an intake, maybe.
Old Jan 25, 2007 | 02:26 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Integra LS Rev Limiter (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote"> Either way, I found that going past about 6500 isnt really faster on a stock LS...with an intake, maybe.</TD></TR></TABLE>
Going any higher will not yield you more power, stock LSengines don't make it that high,
So shifting around 6500 will be plenty enough for the track.
Old Jan 25, 2007 | 04:08 PM
JDMbitches's Avatar
Default Re: Integra LS Rev Limiter (CleanLikeJdm)
well i have a b18b1 and i rev it to 6500 and yes my cluster goes to 7200. i would never think of takin my ls over 6500 thats just me tho.
Old Jan 25, 2007 | 04:29 PM
SE3Pimp's Avatar
Default Re: Integra LS Rev Limiter (JDMbitches)
damn idiot drag ricers. honda made the stock 6800rpm for a reason, why would you buy the car and not know if its chipped or not?
Old Jan 25, 2007 | 04:39 PM
7rrivera7's Avatar
Default Re: Integra LS Rev Limiter (EndlessDc2)
Lots of good responses, but there always an idiot that has to chime in and offer NOTHING.
First of all, cars are not chipped - ECUs are. I just got the car yesterday and before tearing down the engine for an LSVTEC rebuild, I wanted to baseline her. I don't have the time to pull the ECU to see if it's chipped and so just wanted to take her to the stock redline at the strip.
How much more logical can I get?
Old Jan 25, 2007 | 06:28 PM
wernhersey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote"> Reving up higher is just kinda pointless.</TD></TR></TABLE>
Not really. There is a point to it, and that is to be higher in the RPM's so that you don't drop out of your powerband in the next gear. But there is a way to be conservative. The ricers that rip all over town bouncing of the limiter don't realize that its a waste. You should shift a little higher than your peak hp so that the rpm's don't drop before the powerband when u shift. I do see where ur coming from tho.
Imprezor
Jul 28, 2008 08:57 PM
95civicracer
18
Feb 19, 2003 06:34 PM
Austin
Sep 5, 2002 12:16 PM
EL-Teg98
Jan 7, 2002 05:18 AM
