ok ive looked a good bit but not 100% on it
ok im picking up a 93 teg gs..ls motor in it obd 0...the motor is bad as far as we have been told....im getting it for 250 bucks....my question is....A.i have a 94 ls obd1 motor. i know i can swap right in,has cable tranny also,well i have an obd 0 to obd1 conversion harness..what exactly do u have to do to convert..i can use the original harness,but do i need to swap injectors and dizzy or can it just be the dizzy. not 100% on this. any input would help a bit more. thanks
If its a 93 its an obd1, 90-91 were ondo and 92-93 were obd1
if your car is a 93 you wont have to worry about converting anything will connect right up. ANd by chance, an odd chance its a obdo http://www.rywire.com has evrythign you need for the conversion form obdo to obd1.
later
Josh
later
Josh
Dinahrex
10
Dec 20, 2010 09:20 AM
NewBorn_EG
Nov 6, 2004 02:13 AM
