jdm p30 ecu question for usdm b16a3
the motor is in the delsol in stock form, but i was wondering if a p30 jdm ecu would run the car? it already have the usdm ecu in it. will it be any different if i plug up the obd1 p30 jdm ecu on the usdm b16a3 motor. feels any different, vtec crossover? fuel/map magement?
just bascially want to know if it worth the time to plug in the jdm p30 ecu in a delsol equip with usdm b16a3 motor.
thanks, Ron
thanks, Ron
It will run the car. The B16A (SiR) has a slightly higher compression than the B16A3. The VTEC crossover is the same, the fuel map will be slightly different. Feeling a noticeable difference is minimal. The limiter will be higher, so watch out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 »</TD></TR><TR><TD CLASS="quote">so are they the same or no ?</TD></TR></TABLE>
I don't think it is since they have two redlines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">The redline is 8200 for the B16A and 8000 for the B16A3. Isn't limiter slightly higher than redline?</TD></TR></TABLE>
the redline in my '94 del Sol VTEC is 8200, and I believe that its a B16A3. B16A2 is 96-97 del Sol VTEC & 99-00 SI motor, with 8000 redline.
racebum
Jan 14, 2009 01:48 PM
shyxboy
10
Apr 20, 2006 04:39 PM
stripes777
Apr 13, 2006 09:01 PM
prelude9999
Feb 22, 2005 10:49 PM
