Help Making F22b1 all motor
well im getting my dads 94 four door accord nd its gold, it already has headers, intake, off bord coil, level one clutch, and a 13 lb fly wheel, so my dad has round 7 grand into the engine itself
so is it worth doing the swap and putting in a H22 block with lsd tranny
or
swaping the head with idk h23 and build it up from there
and just give me your opinions
or
how does he have 7grand into that engine? but your chassis will seriously hold you back as far as racing goes. So doing some weight removal should be something you should consider.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackAccord »</TD></TR><TR><TD CLASS="quote">well 7 grnd total as in suspension and the engine combine i thought about that also like replacing the hood and trunk and the seats with light weight racing seats right?</TD></TR></TABLE>
wrong section your in then
mod should move this to appearance forum
i have for a while but all i have been reading on the other forums that the owners have been swapping them and putting in the h22 block in them i just want to be different and at least a decently fast N/A car
i know what you mean i know what to do with the block like new cams, and have the block port and polish, and all that but is anything else i could do to the block to make it breathe easier
cuz the engine alone had 127784 hard miles on it already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackAccord »</TD></TR><TR><TD CLASS="quote">i know what you mean i know what to do with the block like new cams, and have the block port and polish, and all that but is anything else i could do to the block to make it breathe easier
cuz the engine alone had 127784 hard miles on it already </TD></TR></TABLE>
LOL you obviously dont
ditch the vtec head. the roller rocker system is cool and all but the intake manifold blows donkey dong and the ports in the head are just too damn small. It would be less work and provide the same benefit to swap to the earlier f22a head instead of the h23 head. Same valve sizes (but 5.5mm valve stems instead of 7mm) and Kseries STOMPING flow potential.... if you have the right person do the head.
Seriously just ask Bisi.
If you just want to have a quick car tho do a decent turbo kit with some arp head studs and run about 8-12 psi depending on fuel available and enjoy 280+whp and 300+ torque #s all day. Just spend money on having the car properly tuned.
Rico
Rico
were does a h23 engine comes from what car and if it has a h22 head how much is it pushin to the gro
as i lay dying
Apr 27, 2004 05:54 AM
