Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Pro Stop Cross Drilled Rotors
Old Jan 24, 2007 | 04:51 PM
prostreetonline's Avatar
Default Pro Stop Cross Drilled Rotors
Wet weather, heavy brake loads and exuberant driving all put a lot of stress on rotors, especially those flimsy stock discs. Add some brawn to your brake pedal with the Pro Stop Drilled Rotors. Their cutting-edge design and choice materials will stop you on a dime without leaving you penniless.
Each Pro Stop Drilled Rotor is custom-machined for your vehicle using CNC technology. They directly replace your stock discs, so the Pro Stop Drilled Rotors don’t require pricy, new calipers. And, their wrought from long-lasting G-3000 series grey iron.
On top of quality construction, the Pro Stop Drilled Rotors also employ carefully balanced cross-drilling. Water slices through these holes for tighter grip in harsh conditions. Plus, each hole is radiused for minimal abrasion. Finally, each Pro Stop Drilled Rotor has a stylish, anti-corrosive Gold-cadmium plating, which lasts 3x longer than wimpy Zinc. Includes a 30-day, 1000 mile warranty.
Order here: <FONT COLOR="red">Pro Stop Cross Drilled Rotors</FONT>
Modified by prostreetonline at 8:59 PM 5/7/2007
Old Jan 28, 2007 | 03:39 PM
beak's Avatar
bump it up for you
Old Jan 30, 2007 | 02:55 PM
Default Re: (beak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beak &raquo;</TD></TR><TR><TD CLASS="quote">bump it up for you </TD></TR></TABLE>
Old Feb 2, 2007 | 04:06 PM
bump, plenty in stock!
Old Feb 3, 2007 | 03:09 PM
Thank you for your orders!
Old Feb 5, 2007 | 11:10 AM
bump!
Old Feb 7, 2007 | 10:56 AM
Plenty in stock!
Old Feb 9, 2007 | 05:44 PM
bump!
Old Feb 15, 2007 | 08:53 AM
thank you for your orders!
Old Feb 18, 2007 | 09:08 AM
thank you for your orders...!
Old Feb 21, 2007 | 11:47 AM
bump!
lude98SH
Sep 24, 2006 04:02 AM
AFAccord
Jun 24, 2005 05:02 AM
prostreetonline
17
May 14, 2005 03:28 PM
mechengine
Apr 3, 2004 10:48 PM
lazy bum shaughn
10
May 1, 2003 10:31 PM
