F20B IACV Wiring 0BD2B - 0BD1
Old Jan 24, 2007 | 04:35 PM
SiR-T's Avatar
Default F20B IACV Wiring 0BD2B - 0BD1
has anyone done this on their F20B? if so could someone give me the details on how to do it?
thanks
Old Jan 26, 2007 | 08:03 PM
SiR-T's Avatar
Default Re: F20B IACV Wiring 0BD2B - 0BD1 (SiR-T)
anyone
Old Feb 9, 2007 | 10:39 AM
F20B_Lude's Avatar
I need help with this too!!!!
Old Feb 9, 2007 | 03:21 PM
street_accord94's Avatar
most people i know that run the euro-r IM (uses the same obd2 3 wire iac valve) convert to an obd1 2 wire...just need to make an adapter plate, or find one ready made
Old Feb 9, 2007 | 07:19 PM
F20B_Lude's Avatar
Default Re: (street_accord94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_accord94 &raquo;</TD></TR><TR><TD CLASS="quote">most people i know that run the euro-r IM (uses the same obd2 3 wire iac valve) convert to an obd1 2 wire...just need to make an adapter plate, or find one ready made</TD></TR></TABLE>
How would I make one or where would the third wire go? Thanks for the help
Old Feb 9, 2007 | 10:16 PM
Default Re: (F20B_Lude)
on an obd1 system the 3 wire iacv wont work, youll need to get a 2 wire obd1 model. as far as making an adapter you would just have to machine a piece of aluminum in a similar manner as this: http://blacktrax.net/productli....html
Just making sure you have it large enough to cover the original iacv location, then seal it up.
Old Feb 10, 2007 | 01:34 PM
F20B_Lude's Avatar
Thanks a bunch
Old Feb 21, 2007 | 07:29 AM
AlmostJDM's Avatar
rosko on here sells these adapter plates i just bought one form him there $35 shipped hit him up
Old Feb 23, 2007 | 03:35 PM
AlmostJDM's Avatar
Default Re: (AlmostJDM)
wait the euro r adapter plate wont work the screw hole are on the wrong sides heres a pic of the F20B iacv
and the adapter plate
itll have to be cutom made
Modified by AlmostJDM at 10:55 PM 2/24/2007
Old Aug 8, 2014 | 05:53 AM
hondaguy20's Avatar
Hey did you figure it out and get it to work? I also have a 99 accord with a f20b motor running off a obd2a h22a p5m usdm ecu with a iac cel ne3d to convert 3 wire to 2 wire also what did you do and does it work??? Please help alwayzb4reel866@gmail.com thanks
hammergunner
Nov 23, 2009 08:24 PM
superfast666
Mar 22, 2008 07:29 AM
2nrz
Jan 21, 2008 08:11 PM
ATgrills.com
Jun 10, 2004 05:40 AM
ATgrills.com
Jun 10, 2004 05:39 AM
