civic swap axle HELP
ok i repalce the drivers side axle right well it has a b18 ls motor out of a 93 integra im guessing because it has the half shafts well i get everything put together and when i tunr hard i still here a grinding can it be the wroung axle it has 5 lug itr swap on it it has size 32 mm axles umm can sumone help me
no its a 32 mm nut on it, the question is it has male and male ends on the old shaft 94.00 integras has male to female , And i bought a axle from a 93 integra and its 4 mm too short like it bolts up and everything but when i tighen the nut it pulls it towards the rotor and shortens it up , its almost like i need a spacer, is there anyway i can use a huge washer , or Do i need to change my intremiet saft to one with a male end on it and use 94 + integra axles Any infor will help me my cars down and i have nothing eles to drive so thanks , Hit me up on aol Eane354
stevenstixx
May 13, 2014 09:48 AM
Hybrid axle: 90-93 Integra axle shaft mated with ED6 axle end in order to use ED6 spindle/hub assemb
integrawow
Jul 2, 2007 02:20 AM
h22ame
Mar 3, 2004 05:00 PM
