smog problem, need assist on problem?
Old Jan 24, 2007 | 01:01 PM
civichbpinoy's Avatar
Default smog problem, need assist on problem?
i have a 95 civic hatchback with a 95 LS swap.. i have passed all the test required except edmissions.. i passed 2 out of 3 that was needed for the edmissions, and it was that i was high in NOX.. and im not shuree where to start to finding out what the cause of the problem is?... anyone that knows how to deal with this situation or knows something that maybe causeing this, please post... thank you
and for my TEST RESULTS
I had passed the VISUAL, FUNCTIONAL, and failed EDMISSIONS
HC (PPM)
15mph-40 .............. MAX was supposed to be 89 so i passed
25mph-23 ...............MAX was supposed to be 54 so i passed
CO (%)
15mph-0.01 .................. MAX = 0.53 PASS
25mph-0.00 ....................MAX = 0.51 PASS
NO (PPM)
15mph-2239 ................. MAX = 708 FAILED!!!
25mph-1821 .................. MAX = 746 FAILED!!!
Modified by civichbpinoy at 9:23 PM 1/25/2007
Old Jan 24, 2007 | 01:26 PM
Hi_Boost's Avatar
Default Re: smog problem, need assist on problem? (civichbpinoy)
may be your running to rich
Old Jan 24, 2007 | 01:31 PM
SmogKing's Avatar
Need mo info, How was the HC(hydrocarbons) reading?
Old Jan 24, 2007 | 01:35 PM
SmogKing's Avatar
Post them NOX numbers also
Old Jan 24, 2007 | 03:29 PM
jay_cue's Avatar
Default Re: smog problem, need assist on problem? (Hi_Boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hi_Boost &raquo;</TD></TR><TR><TD CLASS="quote">may be your running to rich</TD></TR></TABLE>
High NOX would be from running too lean
rloomis482
67
May 21, 2009 10:02 AM
blackhatchsd
Mar 7, 2007 03:30 AM
JV
Jul 2, 2002 06:05 PM
