Oil and Coolant Overflow tanks
Old Jan 24, 2007 | 07:48 AM
732xghost's Avatar
Default Oil and Coolant Overflow tanks
http://www.tein.com/okuyama_ETC.html
^^^^ if i buy these would these cancel out my existing coolant resvior and oil resvior?
Old Jan 24, 2007 | 08:59 AM
Ross 2.0's Avatar
In a Junkyard near you.
You can't replace the oil pan with that no.
The coolant tank looks like it could replace the existing overflow if it was installed right and modified a little, but that doesn't look like what it's designed to do
Old Jan 24, 2007 | 09:08 AM
iam7head's Avatar
Default Re: Oil and Coolant Overflow tanks (NJ JDM CL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJ JDM CL &raquo;</TD></TR><TR><TD CLASS="quote">http://www.tein.com/okuyama_ETC.html
you can simply replace your oem coolant overflow with anything, coke bottle, used condom, a keg, you pick.
the oil reserivor is more like a catch can.
Old Jan 24, 2007 | 10:27 AM
lunarone's Avatar
Default Re: Oil and Coolant Overflow tanks (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
...used condom...
i bet you don't see many of those
jk
but really, what's wrong with oem reservior?
Old Jan 24, 2007 | 11:25 AM
732xghost's Avatar
nothing wrong, im just trying to make my engine bay a little sharper, and trying to get rid of some of the clutter and such.
so basically the coolant overflow DOES or CAN replace the stock resvoir, correct?
but the oil resvoir does not replace the existing resvoir?
Old Jan 24, 2007 | 11:34 AM
Ross 2.0's Avatar
If you can do it <u>tastefully</u> you can paint the stock units and it can look better. But you have to be careful with the color and how you paint it
Old Jan 24, 2007 | 12:53 PM
JimBlake's Avatar
Default Re: (NJ JDM CL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJ JDM CL &raquo;</TD></TR><TR><TD CLASS="quote">... but the oil resvoir does not replace the existing resvoir?</TD></TR></TABLE>Can you explain what you mean by the existing oil reservoir? I'm not aware of any Accord that has a stock dry-sump oil system.
Old Jan 24, 2007 | 05:40 PM
732xghost's Avatar
forget it your absolutely right. i got the power steering resvoir confused with something totally different. my bad.
Old Jan 24, 2007 | 09:13 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJ JDM CL &raquo;</TD></TR><TR><TD CLASS="quote">forget it your absolutely right. i got the power steering resvoir confused with something totally different. my bad. </TD></TR></TABLE>
Niiiice
$190 for an overflow tank is a bit of a waste of $$$, no? Look on Summit or Jegs and you can find lots of them for $50-60.
Old Jan 25, 2007 | 06:43 AM
732xghost's Avatar
i saw them on ebay for $89. by the way should i get the smallest capacity. i obviously dont need a larger capacity.
welfarepc
Jan 10, 2007 10:26 AM
igo4bmx
Aug 7, 2006 10:29 AM
racingfan
May 2, 2006 11:19 AM
nota-eg
Aug 15, 2005 07:17 AM
SNsLude
Jul 7, 2005 11:12 AM
