Engine revving up and down from a cold start.
Old Jan 24, 2007 | 05:45 AM
Hammer01's Avatar
* B A N N E D *
Default Engine revving up and down from a cold start.
1997 Honda Accord DX, 5 speed, non-vtec.
SO for several years I've had the problem where I start my car up cold and it idles up and down for about 2 minutes on it's own, then levels off. Well, this past week, the CEL came on and I pulled a code P0505 Idle Control System Malfunction. I don't know if what I mentioned is anything related to this or not, maybe you lot can help?
I've searched around the internet and I've seen that some mostly say it's a clogged IAC valve, and you can clean it. Others say a vacuum leak. My question is, when the CEL comes on for this, what "typically" is the cause of the problem and what is the solution? I figured you lads might know. Thanks!
Old Jan 24, 2007 | 05:58 AM
Hammer01's Avatar
* B A N N E D *
Default Re: Engine revving up and down from a cold start. (Hammer01)
Nevermind, I just found a thread on page two demonstrating how to fix my problem. Sorry mods!
Old Jan 24, 2007 | 07:18 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hammer01 &raquo;</TD></TR><TR><TD CLASS="quote">... some mostly say it's a clogged IAC valve, and you can clean it. Others say a vacuum leak...</TD></TR></TABLE>Because ether one can cause that, and not everyone's car screws up the same way...
Look for vacuum leaks & fix em.
Make sure you remove ALL air from cooling system.
IAC valve - clean it.
FIT valve - clean it; maybe remove cover see if its guts are loose.
Old Jan 25, 2007 | 05:35 AM
Hammer01's Avatar
* B A N N E D *
Default Re: Engine revving up and down from a cold start. (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Because ether one can cause that, and not everyone's car screws up the same way...
On the FIT, are you talking about that think that has two slots on it for tightening?
Old Jan 25, 2007 | 10:23 AM
JimBlake's Avatar
It's #14, I think you take off the round cover on the end & there's something inside that can work loose.
Look around here for a procedure with photos. I haven't had to do this one myself, that's why I'm kinda vague.
Old Jan 25, 2007 | 10:30 AM
Homesickelian's Avatar
sorry to hijack but this seems to be resolved for the most part. What is part 18 for?
Old Jan 25, 2007 | 03:46 PM
hondadude's Avatar
Default Re: Engine revving up and down from a cold start. (Homesickelian)
Well you little ThreadJacker. LOL
If my old memory is correct that is a bracket that has a wire harness clip going into it from under the IAC.
Old Jan 25, 2007 | 05:26 PM
Default Re: Engine revving up and down from a cold start. (hondadude)
k, cause mines just dangling there for some reason.. rofl. I'll resolve that but I wasnt to certain where to put it
choppyEG
Oct 13, 2013 12:37 PM
wgbm92
May 30, 2012 04:09 PM
chikin pickle
Mar 22, 2010 09:54 PM
bigandy90
Dec 11, 2007 05:44 AM
eL
11
Jan 19, 2005 01:13 AM
