D16a6 crank pulley stuck
Old Jan 23, 2007 | 08:20 PM
griz50cal's Avatar
Default D16a6 crank pulley stuck
I'm trying to get the crank pulley off of my 89 crx SI(D16A6). I took off that stupid bolt (a miracle in itself) but the pulley still will not come off. My haynes manual says that it should just slip off and not to lose the key. I also know a guy who took his off of his newer civic and he said it just slipped off.Ive puleld on it hard, rubber malleted it, kicked it, screamed at it, and nothing does the trick. Am i missing something here?? any input would be appreciated because i just want to drive the damn car
Old Jan 23, 2007 | 08:33 PM
RCautoworks's Avatar
Default Re: D16a6 crank pulley stuck (griz50cal)
Make sure the a/c tensioner is not in the way.
Old Jan 23, 2007 | 08:38 PM
griz50cal's Avatar
Default Re: D16a6 crank pulley stuck (90blackcrx)
nothing is in front of it, i can physically grab the pulley and pull on it. though i cant fit a puller in there because of the frame in the way.
Old Jan 23, 2007 | 08:52 PM
griz50cal's Avatar
o yea and i removed the whole a/c system long ago because it didn't work and just took up space
Old Jan 23, 2007 | 11:12 PM
.Manny.'s Avatar
Touching My Member
hit it with wd 40 and spit and curse at it.
that sounds frustrating as hell. try some heat, it might expand enough and then whack it with another mallet.
thats the best i can give you, hope it helps
Old Jan 23, 2007 | 11:20 PM
yz125rider21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by griz50cal &raquo;</TD></TR><TR><TD CLASS="quote">Ive puleld on it hard, rubber malleted it, kicked it, screamed at it, and nothing does the trick. </TD></TR></TABLE> thats a hard part kick at if you ask me lol...try some ky jelly...does the trick all the time...but seriously see if you can get the little key out so you spray some lubrication in there.
Old Jan 24, 2007 | 01:35 AM
SOHCKLR675's Avatar
Well for my first post I shall say this, use a short piece of 2x4 and a handheld mini sledge, and like emeril bam bam mine came off, oh and pb blaster helps a lil. Hope it helps
Matt
Old Jan 24, 2007 | 09:43 AM
89efDUSTY's Avatar
Default Re: D16a6 crank pulley stuck (SOHCKLR675)
wd40...brake cleaner then get two or more screwdrivers and pry it out evenly. I just had to do this like 4 days ago, and you were lucky my crank pulley bolt broke 2 craftsman ratchet wrenchs and a 1/2 drive breaker bar, but its all good because i get new ones for free
Old Jan 24, 2007 | 12:09 PM
griz50cal's Avatar
Default Re: D16a6 crank pulley stuck (89efDUSTY)
hahaha no luck, i broke like 4 extensions, but thats cuz they weren't craftsman so they instantly exploded.
I got the pulley to quit turning using a bolt in 2 of the holes on it and jammed in one of the broken extensions to keep it from turning, i pulled on it so friggin hard and wen it finally gave i went flying and landed in a bowl of old antifreeze and oil.
Ill give your idea a try, is there a way to get the stupid key out maybe? or if i wreck the key can i replace it?Id try this right now but the car isn't at my house.
Old Jan 24, 2007 | 12:45 PM
ekslax's Avatar
71.172.180.139
propane torch the pulley, it'll expand, then you can probably just tap it off with a rubber hammer.
Old Jan 24, 2007 | 01:42 PM
89efDUSTY's Avatar
Default Re: (ekslax)
key off...you mean the cotter pin...it is like super easy to get out why is it complicated for you...i would think wd40 and some sort of wedge
Old Jan 24, 2007 | 04:28 PM
bp's Avatar
bp
Default Re: (89efDUSTY)
I was doing the exact same thing today. tapped at it with a mallet, pull around perimeter and it eventually gave, but my key came flying out. Now can someone help me with the orientation of the key so I can put it back in correctly. a picture would be greatly aprreciated. thank you
Old Jan 24, 2007 | 04:30 PM
89efDUSTY's Avatar
Default Re: (bp)
What key...do you mean cotter pin? "i hope im spelling it right&gt;?"
Old Jan 24, 2007 | 05:31 PM
chimaira989's Avatar
Woodruff key:
cotter pin:
definitely not a cotter pin.
Old Jan 24, 2007 | 05:55 PM
AndrePerras's Avatar
Default Re: (chimaira989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimaira989 &raquo;</TD></TR><TR><TD CLASS="quote">Woodruff key:
cotter pin:
definitely not a cotter pin.</TD></TR></TABLE>
LOL i love when people make posts like that, you're amazing
Old Jan 29, 2007 | 04:33 AM
griz50cal's Avatar
Default Re: (bp)
It doesnt want to budge, i think i want to jsut use a flywheel puller on it, the only problem is the frame is in the way, I'm wondering if i could undo one engine mount and lower the motor a bit safely, i probably should remove my axles first. what do you guys think?
Old Jan 29, 2007 | 05:50 AM
91zSi's Avatar
Default Re: (griz50cal)
You don't need to pull the axle to get the crank pully off!!!!
Just spray wd-40 or any penetrating oil and tap it with a hammer.
BLKFLSH
Apr 10, 2011 01:54 PM
bdiz
Nov 25, 2009 02:05 PM
SuicideSlide
Oct 9, 2004 08:27 AM
HonCiv
12
Nov 15, 2002 10:01 AM
johnzm
Jun 17, 2002 07:19 PM
