AEm cold air intake 94 accord vtec............install
Old May 16, 2002 | 11:34 AM
1bar's Avatar
Default AEm cold air intake 94 accord vtec............install
already did search didnt find anything. Wut is the senors underneath the stock intake. they have hoses runnig from that sensor all the way to the firewall. There is only one opening on the aem. do these senors stay or go? it doesnt look like the intake will fit with if it is there...but so many sensors and vacum hoses run off it.
Old May 16, 2002 | 02:42 PM
unltdacc12's Avatar
Default Re: AEm cold air intake 94 accord vtec............install (1bar)
unplug it.. im not sure what it is but you dont need it.. i think one vacuum hose goes to a little resivoire.. (is that how you spell it?) thing next to the right headlight.. and i forgot about the rest. mine is long gone
[Modified by unltdacc12, 11:45 PM 5/16/2002]
Old Jan 15, 2003 | 08:06 AM
AccordSiR71777's Avatar
Default Re: AEm cold air intake 94 accord vtec............install (unltdacc12)
I would like a bump on this question....I have a 97 EX and i saw the same stuff under there....Whats all it for???
Old Jan 15, 2003 | 09:24 AM
TypeSH's Avatar
Default Re: AEm cold air intake 94 accord vtec............install (AccordSiR71777)
you are supposed to use the foam filter thing for one of the pipings, supposed to put it in a little and leave half the foam thing open to the air. dont be an idiot like mea nd stuff it all the way into the pipe
You cap off one vacuum line by the intake manifold. umm... you only connect 1 hose from your engine to the intake. Follow the instructions, fairly straightforward.
Old Jan 15, 2003 | 12:48 PM
Default Re: AEm cold air intake 94 accord vtec............install (TypeSH)
Ummm...could you clarify that for me, i cant really follow what your talking about....
Old Jan 15, 2003 | 01:31 PM
95sihb's Avatar
1bar
If you have a f22b1 motor the (cai) should look something like this,(note mine is not aem) http://community.webshots.com/image2...9HZNmxt_fs.jpg
note the little black box on top of the battery this is what you are talking about right! It's called resonator chamber. Aem should have given you a little black plug in its kit.(---) actual size of plug. You know the hose that you where talking about that goes all the way to the firewall,.................Well unplug the hose and put the black plug Aem gave you in its place. There is another hose that goes to another black box next to the back of the right headlight like unltdacc1 was talking about . I just pluged that hose up to with a screw... my car runs fine..here are more pics of the resonator chamber http://community.webshots.com/script...bumID=51729574 hope this helps
[Modified by 96accordex, 2:32 PM 1/15/2003]
Old Jan 15, 2003 | 01:33 PM
Canonm7's Avatar
I have a 96 and didn't see any of the sensors that you guys are talking about. I just ripped everything out. Go to a local autoparts store and pick up a K&N Breather Filter good for about 1-2hp. Costs about $15. Then cap off the vaccum line and connect the filter to the crankcase vent. You'll know what it is when you disconnect the hose from your stock intake.
Old Jan 15, 2003 | 01:52 PM
d15dood's Avatar
sensors?
Old Jan 15, 2003 | 02:00 PM
95sihb's Avatar
Default Re: AEm cold air intake 94 accord vtec............install (Canonm7)
What type of motor 1bar?
Old Jan 19, 2003 | 07:56 AM
philipkrotch's Avatar
u dont need nathing. if the intake doesnt have places for it...not necessary
Henry Juliao
Jan 8, 2022 10:12 PM
SickSpeed06Si
Honda Civic (2006 - 2015)
10
Jun 22, 2006 11:57 AM
NaSh123
Dec 7, 2003 08:21 AM
WannAbe_DC5
Mar 14, 2003 09:00 AM
AccordGuy
Jan 23, 2002 05:58 PM
