What to set 2step launch at?
Old Jan 23, 2007 | 06:52 PM
boomersz's Avatar
Default What to set 2step launch at?
bolt on gsr swap in my civic. getting a chipped ecu and the options free so mines as well get some use out of it. so what should i set it at? going to be using drag radials for the street/strip btw too.
also is it worth messing with the vtec crossover with just having bolt ons?
Modified by logiT at 10:12 PM 1/23/2007
Old Jan 23, 2007 | 06:55 PM
. a d a m's Avatar
Default Re: What to set 2step launch at? (logiT)
I suggest going to the track *cough*somewhere you won't get in trouble*cough* and try launching from different rpm. Once you find one where your car doesn't bog too much or spin too much, set it there.
Old Jan 23, 2007 | 06:56 PM
boomersz's Avatar
Default Re: What to set 2step launch at? (. a d a m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m &raquo;</TD></TR><TR><TD CLASS="quote">I suggest going to the track *cough*somewhere you won't get in trouble*cough* and try launching from different rpm. Once you find one where your car doesn't bog too much or spin too much, set it there.</TD></TR></TABLE>
well thing is, its not running yet. i need the ecu, plus misc stuff to get it running.
Old Jan 23, 2007 | 07:48 PM
boomersz's Avatar
anyone else?
Old Jan 23, 2007 | 07:59 PM
egmatt93's Avatar
mines at 4k.. not too good on street but havnt gone to the track yet
Old Jan 23, 2007 | 08:03 PM
Syndacate's Avatar
Default Re: What to set 2step launch at? (egmatt93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egmatt93 &raquo;</TD></TR><TR><TD CLASS="quote">mines at 4k.. not too good on street but havnt gone to the track yet</TD></TR></TABLE>
That's a bit higher on a GSR, but I'm not sure how much the radials will matter.
@ OP: It's really hard to tell - find somebody who's done it before (probably a lot of pple with stock GSR I/H/E).
Old Jan 23, 2007 | 08:06 PM
boomersz's Avatar
Default Re: What to set 2step launch at? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
@ OP: It's really hard to tell - find somebody who's done it before (probably a lot of pple with stock GSR I/H/E).</TD></TR></TABLE>
i guess ill post in the integra section too
Old Jan 23, 2007 | 08:14 PM
egmatt93's Avatar
yea i forgot to say i dotn have a gsr :/ b16 here
Old Jan 23, 2007 | 08:38 PM
boomersz's Avatar
oh
Old Jan 23, 2007 | 08:57 PM
Luserkid's Avatar
No 2 cars are going to be the same. To determine the best 2 step involves alot more then just what motor you have. Most important is the tires your running, that tells you where you should set your 2 step.
Example: Boost and good size slicks youll want it high enough that you build the most boost you can, alot of people set it 2k lower then there max RPM.
Example2: 230whp NA with street tires would be low due to the quick rpms and power is everywhere.
No one could tell you where to have it set. Best thing to do is get a laptop and hit the track and see where you like it. Dont do it on the street because its worthless there. If you dont say anything theyll set it at 4 (which comes with stock basemaps on alot of programs)
Old Jan 23, 2007 | 09:27 PM
boomersz's Avatar
Default Re: What to set 2step launch at? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">No 2 cars are going to be the same. To determine the best 2 step involves alot more then just what motor you have. Most important is the tires your running, that tells you where you should set your 2 step.
No one could tell you where to have it set. Best thing to do is get a laptop and hit the track and see where you like it. Dont do it on the street because its worthless there. If you dont say anything theyll set it at 4 (which comes with stock basemaps on alot of programs)</TD></TR></TABLE>
icic. if im getting it chipped from a sponsor here, how do i change the 2step setting myself?
Old Jan 23, 2007 | 09:35 PM
jayjayek's Avatar
New User
i launch at 2800 to 3000 rpm's that'a not to low u wont spin alot of tire,stage 2 competition clutch,on a gsr.
Old Jan 23, 2007 | 09:36 PM
boomersz's Avatar
Default Re: What to set 2step launch at? (jayjayek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayjayek &raquo;</TD></TR><TR><TD CLASS="quote">i launch at 2800 to 3000 rpm's that'a not to low u wont spin alot of tire,stage 2 competition clutch,on a gsr.</TD></TR></TABLE>
what tires?
Old Jan 23, 2007 | 09:37 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT &raquo;</TD></TR><TR><TD CLASS="quote">icic. if im getting it chipped from a sponsor here, how do i change the 2step setting myself?</TD></TR></TABLE>
Are you getting it from member mtber? His a good guy. In order to change it youll need a chip burner along with a laptop and crome software.
Old Jan 23, 2007 | 09:38 PM
boomersz's Avatar
Are you getting it from member mtber? His a good guy. In order to change it youll need a chip burner along with a laptop and crome software. </TD></TR></TABLE>
either him or kenji. ic, i guess i better pick a good setting then haha.
Old Jan 23, 2007 | 10:53 PM
fmrprojects's Avatar
its gonna be different on the street than on the track. best bet is just get a msd with the 2 step option so you can change it around. you really dont ned a 2 step for stock gsr
CeeJayy
12
Feb 15, 2008 11:50 PM
boomersz
13
Apr 1, 2007 06:05 AM
boomersz
Jan 24, 2007 11:14 AM
boomersz
Jan 23, 2007 11:46 PM
bboylito
Apr 4, 2005 04:20 PM
