What to set 2step launch at?
Old Jan 23, 2007 | 08:07 PM
boomersz's Avatar
Default What to set 2step launch at?
bolt on gsr swap in my civic. getting a chipped ecu and the options free so mines as well get some use out of it. so what should i set it at? going to be using drag radials for the street/strip btw too.
also is it worth messing with the vtec crossover with just having bolt ons?
Old Jan 23, 2007 | 08:13 PM
vaporboy12's Avatar
Default Re: What to set 2step launch at? (logiT)
your going to need to set it pretty high for a basic swap with drag radials. but its not something that should stay the same becasue track conditions changes... what works one day may cause you to spin your *** off the next day
Old Jan 23, 2007 | 08:39 PM
boomersz's Avatar
Default Re: What to set 2step launch at? (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">your going to need to set it pretty high for a basic swap with drag radials. but its not something that should stay the same becasue track conditions changes... what works one day may cause you to spin your *** off the next day</TD></TR></TABLE>
true...i was thinking 4500rpm
Old Jan 23, 2007 | 08:40 PM
vaporboy12's Avatar
way to low on radials
Old Jan 23, 2007 | 08:41 PM
vaporboy12's Avatar
way to low
Old Jan 23, 2007 | 08:44 PM
boomersz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">way to low</TD></TR></TABLE>
what would suggest?
Old Jan 23, 2007 | 08:52 PM
vaporboy12's Avatar
6500-7800 some where in that area
Old Jan 24, 2007 | 01:38 AM
RaceProfessor's Avatar
I would start at 6200rpm and move up in 200rpm increments till it doesn't bog or spin excessively.
Old Jan 24, 2007 | 07:01 AM
RTA Supra's Avatar
Default Re: What to set 2step launch at? (RaceProfessor)
I agree with somewhere in the low 6000rpm range at first. Of course depending on tire pressure, track condition, etc...
Old Jan 24, 2007 | 11:14 AM
fmfkid250's Avatar
launch off rev limiter!!!
97gsrki
May 21, 2007 10:50 AM
boomersz
13
Apr 1, 2007 06:05 AM
boomersz
Jan 23, 2007 11:46 PM
boomersz
15
Jan 23, 2007 10:53 PM
