hitting 9200 rpm when pedal get stuck?
Old May 16, 2002 | 11:10 AM
Hard2Find's Avatar
Default hitting 9200 rpm when pedal get stuck?
did my friend just ruined his stock ITR head? he got a chipped ECU and his pedal got stucked twice last nite while racing in the hwy and he was bouncing off 9200 for few seconds. should he be worried? all he got is I/H/E...
[Modified by Hard2Find, 8:11 PM 5/16/2002]
Old May 16, 2002 | 11:23 AM
siisgood00's Avatar
New User
Default Re: hitting 9200 rpm when pedal get stuck? (Hard2Find)
AHH, thats bad news to hear. Why did the idiot do it twice? Chipped ECU+Big Morons=Blown Motor.
Old May 16, 2002 | 11:26 AM
norice's Avatar
Sounds more like he was bouncing off the rev limiter at an indicated 9200 rpm, which may have been 8600 or so. He is probably fine.
Old May 16, 2002 | 12:04 PM
ITR#00-1077's Avatar
Just because you get a chipped ECU doesn't mean nothing if your motor isn't built for it... that's why in stock form, our redline is at 8400rpm... that is there for a reason... taking it further than that is just a gamble.... why mess up a perfectly good motor...
Old May 16, 2002 | 12:24 PM
t's Avatar
t
Default Re: hitting 9200 rpm when pedal get stuck? (norice)
He will be fine, find out why the pedal got stuck.
Old May 16, 2002 | 01:01 PM
Hard2Find's Avatar
Default Re: hitting 9200 rpm when pedal get stuck? (t)
ok, let me tell you this: HE DID NOT INTEND TO HIT IT PASS 8400rpm...just that the pedal got stuck and wont let go of the gas therefore it hit the 9200revlimiter.
and yes, its 9200rpm coz its chipped (p28 OBDI).
Old May 16, 2002 | 01:09 PM
BudMan's Avatar
welcome to a REALLY bad "head job"!
Old May 16, 2002 | 04:08 PM
DCtwoR's Avatar
He should be fine, just make sure he doesnt do that all day long. ha
Old May 16, 2002 | 05:03 PM
spoon_ek9's Avatar
Default Re: hitting 9200 rpm when pedal get stuck? (RedlineR 106)
yea, he should be ok, since stock itr are made for 9k rpm(in japan).
Old May 16, 2002 | 10:09 PM
b19coupe's Avatar
Default Re: hitting 9200 rpm when pedal get stuck? (spoon_ek9)
He will be fine. Bouncing off the rev limiter is not what kills motors. Missing a shift and mechanically forcing the engine to turn at 10,000+ rpm's is what kills motors. But, fix that throttle before he kills himself!
Old May 16, 2002 | 11:02 PM
SurferX's Avatar
Since when are stock ITR's made for 9k? Japan's ITR tach has the same redline we do. I think lowering the revlimit might be a smart thing to do. If your engine is not prepared to rev to 9200 RPM I don't see why you would want to set your revlimit that high.
Old May 16, 2002 | 11:24 PM
spoon_ek9's Avatar
Default Re: hitting 9200 rpm when pedal get stuck? (SurferX)
well, yea, but the fuel cutoff for 98 spec itr(japan) is 9k rpm. many many video from japan show that. on top of that, itr can rev up to 9k just a chipped or aftermarket ECU. althought the power might drop(depend on ecu setting) a little bit, but it help keeping rpm when upshifting.
Old May 16, 2002 | 11:52 PM
B2FiNiTY's Avatar
Well, I think the 9k fuel cut is because the tach is off.
Syndacate
14
Mar 13, 2020 01:59 PM
Tealeg88
19
Jan 20, 2006 06:00 PM
droopy
Mar 1, 2005 09:10 AM
gaskleppie
Jun 25, 2004 10:42 PM
1GreyTeg
Dec 2, 2002 01:56 AM
