Axle sticky picture not working?
Old Jan 23, 2007 | 05:00 PM
Mr. Giggles's Avatar
Default Axle sticky picture not working?
Does anyone else see the pictures on how to remove an axle?? I can't see them, is there another place i can look.??
Old Jan 23, 2007 | 05:03 PM
Tyson's Avatar
Default Re: Axle sticky picture not working? (SmrCRX)
unfortunately a lot of the links in the FAQ used pics with links to we-todd-did which is no longer working.
what do you need help with?
Old Jan 23, 2007 | 05:07 PM
Default Re: Axle sticky picture not working? (Tyson)
I would just like step by step pictures on the removal of axle's
Old Jan 23, 2007 | 05:12 PM
e jay one's Avatar
take a screw driver and bang out where theres a dent in the large axle nut then take that nut off 1 1/4" socket. then take off the lower ball joint nut and seperate useing the craftsman 1/2" drive ratchet trick. then pull the hub out and tap the axle end out of the hub. then take a large screw driver or pry bar and pry the other end of the axle out of the tranny.
Old Jan 23, 2007 | 05:18 PM
mat18's Avatar
Removing an axle is very easy. The thing is, it is very time consuming. I will try to find you a guide.
Old Jan 23, 2007 | 06:15 PM
dr_latino999's Avatar
Default Re: (mat18)
1) Car is on ground, wheel is on, remove the center cap that hides the axle nut.
2) Unstake the Axel nut with a screwdriver, or a strong pick.
3) While car is still on the ground hit the axle nut with an air gun (134 ft/lbs )
3a) If no air gun is available, have someone apply the brakes and possibly put the car in a high gear (passenger wheel put in 5th, driver's wheel put in reverse). Breaker bar + PB blaster and put some back into it.
4) Once axle nut is loose, remove lugnuts
5) Jack up car, place on jackstands
6) Remove wheel
7) Disconnect sway bar endlink from LCA
8) Disconnect Shock fork from LCA
9) Disconnect radius rod from LCA
10) Disconnect LCA from Rear Crossmember
10a) Notice how you didn't have to deal with that stupid ball joint, thank me later
11) Pull knuckle away from axle splines
12) Prybar between transmission case and axle, should pop right out.
grjr
Aug 23, 2012 04:12 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
LS94tegra
Apr 19, 2008 11:59 AM
DubyaAye
Oct 29, 2005 05:45 PM
RicedREX
Feb 26, 2004 05:33 PM
