Those of you running Lude LMA's in B Series heads....
I understand the washer thickness needs to be .040" but what is the diameter? I already bought 2 different sizes, including #10 washers from Home Depot that a member suggested.
Are they supposed to be snug in the LMA bore or is there supposed to be space in there for it to move around? #10 washer was too small for the bore.
I need the exact diameter of this washer. Thanks in advance
Modified by MARVNVRAM at 7:34 PM 1/23/2007
Ok well after this post i made measurements for myself and bought a 5/8" outer diameter .040" thick washer and it fits almost perfect. It has VERY little room to move around at the bottom of the bore.
What is the outer diameter for the washers you're using? I will post pics to show what I'm talking about.
hatchback19
Jan 31, 2004 01:50 PM
New Image
Oct 19, 2003 07:03 PM
