problems lowering my 03 civic si can anyone help
Old Jan 23, 2007 | 02:41 PM
ROB8387's Avatar
Default problems lowering my 03 civic si can anyone help
trying to lower my 03 civic si bought skunk2 lowering spring but for some reason two front sides are both at same hieght but the two back sides are uneven one back side is a 1/4 inch higher than the other side so two front sides are 23 inches off the ground left backside is at 23&3/4 and right back side is at 24 inches off the ground can anyone trell me what could be wrong.
Old Jan 23, 2007 | 02:44 PM
...me0w's Avatar
do you have the spring seated properly
Old Jan 23, 2007 | 02:48 PM
ROB8387's Avatar
Default Re: (...me0w)
i think so its at the bottom the same as the other side could it have something to do with the shocks i still have the stock ones
Old Jan 23, 2007 | 02:56 PM
melvin's Avatar
Default Re: problems lowering my 03 civic si can anyone help (ROB8387)
eh i had those for my rsx-s and it did the same thing. check if you have the front and rear springs correct, because when i got them the numbers on the springs didn't match what it said. so correct me if i'm wrong. i don't know if that will help =/
om_youssef
Honda Civic (2006 - 2015)
May 23, 2018 06:05 AM
mosthated
Suspension & Brakes
May 30, 2017 03:35 PM
swtreaper
Apr 21, 2012 10:31 AM
JohnnyB70
Mar 14, 2005 04:56 PM
Shiftkit
Feb 5, 2004 06:00 PM
