low idle....engine dies when stepped on throttle in neutral!
hey guys. i am new to this forum. i hv searched and searched all sites and hv blistered my index finger on my right hand. lol. so here is my problem. my car has a low idle and stalls when i rev the engine when in neutral. the car has no mods except for a aem intake. i hv
-cleaned the iacv(twice)
-cleaned and tightened fitv screw,
-cleaned tb(replaced gasket)
-cleaned egr ports, valve(twice) and replaced gasket
-replaced pcv
-bled coolant
-new oem plugs, wire, dizzy
-checked for vacuum leaks
nothing helped a bit. strangest thing is there are NO cels.
now for the questions
1)could a faulty map or tps do this?
2)timing belt service was done recently do u think timing being off could cause this?
3)what else could cause thiis?
any suggestions r welcomed and appreciated. thnx.
-replaced pcv
-bled coolant
also, when i do the cel checking using the paper clip method, my atts light flashes giving me code 43. using this http://www.geocities.com/riced....html it gives "asbolute manifold pressure". what does that mean that my map is bad or that i have a vacuum leak?
when my atts would mess up, it always gave me a code 43...too bad i'm not a honda tech. i never knew what that code was.
have you checked your spark plug wires? are they all going to the distributor in the correct order? i can't think of anything else that wouldn't throw a code
It's not done yet but, pretty soon it will be a nifty decoder.. It's still running beta I had a confusion in DTC and wasnt sure how to enter the values in html format but, of course i won't tell unless that person uses that code
Update: so far it's working 100%
You have all the codes? If you have any problems with coding anything, pm me the problem area. I'm a computer programmer with the Air Force. I'd be more than happy to help you out.
Your right it would not I would always follow Helms.. I think it's turning out to be the book of day for me.
Air force .. I can see you guys bobin your heads with nelly. I'm not really experianced in codeing but,
Hotel-oscar-whiskey mike-uniform-charlie-hotel charlie-oscar-delta-echo delta-oscar yankee-oscar-uniform Kilo-november-oscar-whisky ?
it sounds like your running too rich bro, your timming could be off or your belt off a tooth causing the spark to happen to soon, or you map sensor had fucked off on you. try pulling off your vacume line from the map sensor and play around with pluging it or wide open or giving it half vacume if this helps then you know its your map sensor man...
good luck
-Mikey
good luck
-Mikey
dcdcdc
Aug 1, 2008 07:08 PM
