harness 91 integ b18a1 into 94 ex.
i need to know which harness to use. im thinkin bout just chopping up them both and using my ex harness. but then would i have to take the wires at the kick panel. cut them and then connect them to lines up with the integ ecu plugs?
ok. but if i use the EX harness. i have to change almost all the plugs right? cuz the ones from the b18 are different sizes on alot of them. and i still need to kno if i take like 4 inches of wire and the plug from the teg. and make a jumper harness thing for the teg ecu.
