How to wire resister box for h22 with dsm 450s????
I am doing a turbo setup in my 95 civic hatch with h22 and im wondering how to wire the resister box that came with the dsm 450s that i got, if any one knows please post somthing thanks??
^x2
Definitely go with the inline resistors. It's cleaner than using the resistor box. I've had mine for 1 1/2 years.
what are inline resistors and whats the difference between them and the box... i already have the new box so should i still go with the inline??
if you have a resistor box and it is hooked up then no you don't need to do the inline resistors. You do one or the other.
if you have the resistor box then just plug in your dsms.
The resistor box and inline resistors have the same function. You will not need to buy them if you do not want to. 1GPlusSH was only saying that you have other option if having the box under your hood bothers you. im not sure how you would install it in a car that did not have on from the factory since it only has two wires comming out of it . i would assume you splice the box in between the injector and the ecu
search Google http://robskills.wordpress.com...loom/
search honda-tech
https://honda-tech.com/zerothread?id=517274
https://honda-tech.com/zerothread?id=736737
search honda-tech
