FS/FT: 1998 GSR shortblock
Steven, 512-296-9602
im selling my 98 gsr shortblock...all internals in working condition...no oil leaks or coolant leaks...no smoking at any rpm
thing is, there is slight damage to the block at the engine code...if you all remember, new years eve morning my clutch exploded and blew through the transmission...when that happened, the chunk of transmission was connected to the block via a tranny bolt...here's pics of the damage
you can see on the right is the block, there is chunk missing...no holes in the block, oil and coolant were not effected
on the left is transmission bell housing, on the right is engine block...connected with a tranny bolt...parts are kinda brown because i used a high temp black paint and it came out like that
asking $200...includes block, pistons, rods, crank, water pump and oil pump (still assembled)...no timing covers or crank pulley
<U>considering trades as well:</U>
**high volume b-series fuel rail
**adjustable b-series fpr
**obd0-obd1 conversion parts--
-obd1 vtec distributor
-obd1 vtec ecu (p28, p61)
-obd0-obd1 conversion harness
**make offers
**make offers
