wiring help!
Old Jan 23, 2007 | 04:14 AM
lsracer27's Avatar
Default wiring help!
one night i was drivin my 99 LS and when i got home i noticed my runnning light(tail lights, corners and license plate lights were all off) so i checked all the bulbs and they worked fine. My turn signals and brake lights both worked fine so i replaced the fuses for the running lights. I replaced it about 5 times but everytime i tried to turn them on again the fuse blew immediately....wat could my problem be?
Old Jan 23, 2007 | 09:18 AM
95 integra's Avatar
Default Re: wiring help! (lsracer27)
bad wiring (grounding out somewhere). You can try using a fuse 5 amps larger then the stock one and see if it blows (ONLY use one 5 amps larger, going beyond that results in melted wires and all kinds of good stuff). If the larger one blows its a ground problem.
Old Jan 23, 2007 | 04:09 PM
lsracer27's Avatar
Default Re: wiring help! (95 integra)
ok ill try that tomorrw ill get back to u thx
Old Jan 27, 2007 | 08:09 PM
lsracer27's Avatar
ok so i tried using the larger fuse, and the running lights flickered on for a split second then shut off again like the fuse blew.....only this time the fluse didn't blow!? the bulbs and connections are good and i replaced the fuse with at least 3 other ones and neither of them blew....please help!
akrite
Jun 5, 2012 04:20 PM
thisboyjulio
Nov 10, 2008 03:50 PM
darr3nm
Lighting
Feb 10, 2008 08:16 PM
CJ_2Dr
Jul 28, 2006 08:01 AM
Joey B 18C
Feb 18, 2005 06:58 AM
