crx spring rate question.
Old Jan 23, 2007 | 12:15 AM
remoer's Avatar
From: fountain inn, sc. where they still rock banjos on porches, usa
Default crx spring rate question.
i was searching and i found a several threads on spring rate. i was a bit lost. now i'm upgrading my suspension but the problem i'm having is inturpting the spring rate. i was looking in get a set of Tokico Hp blues. for starters. now the spring rate of the springs were 280F & 230R. now there was another set w/a rate of 265F & 165R. the there was a set of true coilover that was 12kg F & 6kg R. can some on help me a bit on decphering this. i will dropping them on my 90 rex w/a 22mm r/sway bar. i want to have a bit aggressive supension while still being able to use it as a DD.
Old Jan 23, 2007 | 12:46 AM
djphonics's Avatar
Default Re: crx spring rate question. (remoer)
The 280/230 numbers are lb/in (pounds force per inch). The 12/6 numbers are kg/mm. Take that number and multiply by 9.8 and you have N/mm (Newtons per mm), which is what Ground Control uses in their part numbers of their Eibach springs. So, specifically, that setup you were talking about is:
12kg F & 6kg R = 672 lbs/in F & 336 lbs/in R
If you order the ground control kit for the CRX, the default setup is 350F/250R. This is what I have and it seems pretty decent for street but honestly I will probably be going to higher rates for the track. A lot of autocross guys are running stiffer springs in the rear. It depends what you are doing. Also, it depends what shocks you have.
Old Jan 27, 2007 | 08:40 PM
remoer's Avatar
true about running higher rate in the rear but everwhere i look it's the same thing everywhere the fronts are very high spring rate while the rear is half of the front. and yes i understand that the front needs to be a bit heavier due to the motor but getting a balance is a bit harder than on thinks. here's some example:
Megan Racing Full Coilover Dampers
f/12kg & r/6kg
Megan Racing Springs
f/280 & r/230
TEIN Basic Coilovers & Super Street
f/448 & r/224
TEIN S.Tech Springs
f/269 & r/236
Tokico Hp Blues w/Springs
f/266 & r/156
and well trying to get spring rates from other spring/coilovers companys well it's like pulling teeth.
what are stock spring rate. wait a sec. i sense a flame coming on. i'll see if someone posted them here somewhere. search button to the rescuse....
EDIT: well the only thing i found was: 96-00 EX - 165F/80R. so which led me to believe that the Crx should be a wee-bit lower. well it's a start.
Modified by remoer at 1:20 AM 1/28/2007
aznriceryder
Suspension & Brakes
Oct 26, 2007 09:37 AM
slow91crx
Suspension & Brakes
15
May 17, 2005 08:26 PM
96-EJ6 B18C
15
May 18, 2004 07:48 PM
gen2lsvtec
Aug 31, 2002 02:43 PM
InstantRamen
Aug 10, 2001 10:02 PM
