How to tell motor is OBD1 or OBD2?
Old Jan 22, 2007 | 10:05 PM
boomersz's Avatar
Default How to tell motor is OBD1 or OBD2?
How can you tell that a motor is OBD1 or OBD2?
Old Jan 22, 2007 | 10:16 PM
integra racr04's Avatar
Default Re: How to tell motor is OBD1 or OBD2? (logiT)
what year is it??
im pretty sure that everything under the year of 95 is OBD1, everything newer is OBD2....anyone care to correct me??
Old Jan 22, 2007 | 10:20 PM
boomersz's Avatar
Default Re: How to tell motor is OBD1 or OBD2? (integra racr04)
well the head looks to be stamped 94 i dunno about the block. just want to make sure...
Old Jan 22, 2007 | 10:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT &raquo;</TD></TR><TR><TD CLASS="quote">well the head looks to be stamped 94 i dunno about the block. just want to make sure...</TD></TR></TABLE>
look the motor code on the block...
Old Jan 22, 2007 | 10:26 PM
boomersz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra racr04 &raquo;</TD></TR><TR><TD CLASS="quote">
look the motor code on the block...</TD></TR></TABLE>
is there any other way to tell? im pretty sure the whole thing is a obd1 cuz the head is a 94 and theres no vin's. obd1 and down didnt have vins, correct?
DA6righthand's Avatar
you cant tell by looking at the block.
96 and up is obd2. 95 and down is obd1.
Old Jan 22, 2007 | 10:27 PM
boomersz's Avatar
Default Re: (DA6righthand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA6righthand &raquo;</TD></TR><TR><TD CLASS="quote">you cant tell by looking at the block.
96 and up is obd2. 95 and down is obd1.</TD></TR></TABLE>
everythings there i think, complete minus ecu
Old Jan 23, 2007 | 10:26 AM
boomersz's Avatar
Default Re: (logiT)
im guess its a 94 then...did all 94-95 gsr's have hydro tranny's?
Old Jan 23, 2007 | 11:41 AM
Default Re: (logiT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logiT &raquo;</TD></TR><TR><TD CLASS="quote">im guess its a 94 then...did all 94-95 gsr's have hydro tranny's?</TD></TR></TABLE>
yes
Old Jan 23, 2007 | 12:29 PM
pennies_hatchie's Avatar
Default Re: (integra racr04)
96+ should have vins on the bottom of the blocks and tranny. also the block should have the ckp sensor by the pully's. the head should also be stamped with a newer year as well. also check the dizzy, it should have 1 plug vs 2 plugs.
Old Jan 23, 2007 | 05:54 PM
boomersz's Avatar
Default Re: (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie &raquo;</TD></TR><TR><TD CLASS="quote">96+ should have vins on the bottom of the blocks and tranny. also the block should have the ckp sensor by the pully's. the head should also be stamped with a newer year as well. also check the dizzy, it should have 1 plug vs 2 plugs.</TD></TR></TABLE>
head is stamped 94, no vins but theres a sticker on the tranny.
ckp same as cfk? http://www.ff-squad.com/tech/sensors/ckf.jpg
Old Jan 23, 2007 | 05:59 PM
Import_spoon's Avatar
My Old 95 Integra ls was OBDII. Its all stock too it was lady driven all its life.
Sumslapper
Jul 19, 2009 06:54 PM
92integraVTECgsr
Jun 1, 2008 04:30 PM
92integraVTECgsr
Feb 15, 2006 12:39 PM
IEATLINT
Aug 10, 2003 09:08 PM
SPOONfdEK
May 27, 2003 06:32 PM
