stock height
you can get an alignment with the car dropped, just have them adjust toe and caster.
bad toe kills tires first, not camber. you'll be fine as long as you are not dropped like 4".
how bout if i used washers to shim out the camber angle in the rear? because les schwab said i couldn't have it aligned if i had that, that i would actually have to buy a rear upper control arm camber kit?
Noah Santana
11
Jan 18, 2017 06:09 AM
