ITR???
Old Jan 22, 2007 | 08:48 PM
Cesar_CPR's Avatar
Default ITR???
Will the ITR suspesion fit on my sohc or do i need to have B-series.
Old Jan 22, 2007 | 08:50 PM
vtec4lyfe's Avatar
it has nothing to do with the motor! it has to do with the year/chassis of the car my friend.
Old Jan 22, 2007 | 08:51 PM
pkdog167's Avatar
Default Re: ITR??? (JDMFLAVOR)
......what kind of car you having.....well I don't think you can bolt a suspension to you engine sir...
Old Jan 22, 2007 | 08:52 PM
pkdog167's Avatar
Default Re: ITR??? (pkdog167)
lol vtec4lyfe just post it a min faster then me....
Old Jan 22, 2007 | 08:54 PM
Cesar_CPR's Avatar
I have 92 civic si.
Old Jan 22, 2007 | 09:02 PM
LiL JoN's Avatar
Old Jan 22, 2007 | 09:18 PM
CapnKrunch's Avatar
Default Re: ITR??? (LiL JoN)
Most likely it will. Integra suspension will fit on most 1992-2000 civic chassis I'm Pretty sure.
Old Jan 22, 2007 | 11:33 PM
AK_20_EM1's Avatar
as long as its usdm itr suspension youre good to go. sohcs are 32mm. same as b series.
Old Jan 23, 2007 | 05:11 AM
MasterKwan's Avatar
Default Re: (AK_20_EM1)
ITR rear suspension's not useable on the 96-00 Civics. They changed the length of the lower control arm.
Old Jan 23, 2007 | 05:45 AM
pennies_hatchie's Avatar
depends what you mean by suspension?
if you mean just the shocks/springs then yes. all you need is the rear itr lca and it will bolt on. fronts will bolt in just fine.
if you mean the itr 5 lug, then you would need to get the usdm itr 5 lug since you're going to be using the 32 mm for the fronts so yes, it will work. you have to get the whole rear assembly for it to work with your arms as well.
mrdeadman
Mar 20, 2006 03:56 PM
egb18c5
Jan 4, 2006 09:21 PM
sUpMaAhChInX
Nov 28, 2003 06:11 PM
serious
Dec 11, 2002 08:33 AM
tweekerz
May 6, 2002 05:59 AM
