Rear Sway Bar
Hey there got a question, im planning on upgrading to a larger rear sway bar on my 05 lx. Should I go with the dc5 oem 22mm or the comptech 22mm. Both include bushings and I can get them at virtually the same price (plan to re-use factory endlinks). Which should I go with? As well I have a maganaflow cat-back exhaust setup, upgrading wont cause the sway bar to rub against the exhaust will it, assuming not but just to be 100% certain I am asking
Thanks
Thanks
Considering the stock one is tiny - 13 mm, everything is a huge upgrade.
Question, the sway bar brackets, that hold the middle of the bar up, what do you guys replace that with when upgrading?
EDIT - sorry 13 mm. haha
Modified by carbnjunkie at 10:22 AM 1/25/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G »</TD></TR><TR><TD CLASS="quote">did you just say the stock rear sway is 19mm?
:/</TD></TR></TABLE>
for a usdm dc5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbnjunkie »</TD></TR><TR><TD CLASS="quote">Considering the stock one is tiny - 19 mm, everything is a huge upgrade.
Question, the sway bar brackets, that hold the middle of the bar up, what do you guys replace that with when upgrading?</TD></TR></TABLE>
You can still use your stock ones from the 12mm sway
for a usdm dc5
If you have the 19mm sway bar, you can use the 3/4" polyurethane bushings/brackets from Energy Suspension.
gakkuken
21
May 23, 2003 02:29 PM
