Parting out my CRX, added more parts!
Old Jan 22, 2007 | 07:51 PM
DC5Tuner's Avatar
Default Parting out my CRX!
1, 88 CRX Si door panels (Driver's side has some small tearing at the very top edge that sits against the window, other then that, they're clean). Sold!
2. Rear hatch interior panels, I have two sets of these. $50 a set, come complete with pockets and interior hatch light Sold one set!
3. Rear hatch interior center panel Sold!
4. Door Sills (Driver's side has a crack near the hood latch release area) Sold!
5. OEM spare tire, jack and jack handle Sold!
6. AC Compressor, previous owner said it worked fine but my AC didn't work due to a bad (leaky) condensor. Should be fine, never had working AC though due to the condensor, pulley isn't seized or anything. Sold!
7. Spare Tire Cover Board Sold!
8. Gauge Cluster Hood (88-89 style) Sold!
9. CRX Si Gauge cluster (88-89 style) $50
10. OEM passenger side lamp (brand new, was only on the car for about a month) $25
11. Amber Turn Signals (88-89 style). Include working bulbs + bulb housings. $20 for both
12. Map sensor, dashbot, etc, firewall assembly for a d16a6. Sold!
13. Driver's side lower door molding + side skirt (painted Championship White) Sold!
14. CRX Glove Box Sold!
15. CRX Si steering wheel Sold!
16. Fuse Box (underhood, comes complete with good fuses) $15
17. Rear Speaker Covers Sold!
18. Front Speaker Cover (I Believe I have the other one somewhere at home) $10 for both
19. CRX Si D16a6 Factory Intake + Resonator Box Sold!
20. CRX Si front shocks (no leaks or anything) Sold!
21. Headlight/Wiper Combination Switches $40
22. Speaker mounting plates = Sold! Rear Speaker Main holdsters that the plates bolts up to. Sold!
23. 88 Style B-pillar mounted seat belts (they don't go through the door!) Also have the buckles that they plug into. Sold!
24. Rear Defroster Switch $15
25. Fog Light Switch (It appears to be the USDM OEM switch, not 100% sure though) Sold!
26. Front Speaker Pods (Got these brand new from honda, were only on the car for a month). $15
27. 88 CRX Si front lip. Sold!
28. New Axles, boots aren't torn or anything, in perfect condition. Weren't on the car for more then a few months. Sold!
29. Interior Fuse Block (complete with all working fuses).
30. Main Relay, works perfect $15
31. EF Hatch Cargo Cover Sold!
32. Rear "wheel houses"...I was told by the body shop I needed these pieces, brought them the part, they said they didn't need it, it wasn't the the same part they were thinking of, didn't have the boxes they came in (tossed them out), so I couldn't return these.
These are brand new from honda, they cost ~195 bucks a PIECE! (make me a offer please!)
33. CRX Si Thermal Stainless Steel Catback + Test pipe Sold!
34. CRX seats. Sold!
35. CRX Passenger Fender. Sold!
36. CRX Passenger Door, VERY clean, includes all moldings including the one that goes against the glass to keep rain out. The inner weather strips are also brand new oem pieces. It has glass, regulator, and crank handle as well. It's only missing the side mirror + inner door panel. $200
37. OEM CRX Hatch shocks, JUST replaced these things, they cost 70 bucks retail a PIECE. Looking for $50 for both.
38. ITR Alumium Shift **** Sold!
I also have a few other things not pictured....
***88 CRX Si Engine Harness (11/8/06)*** (includes injector resistor box, etc), Sold!
***88 CRX Si Dash Harness (11/10/06)*** This thing is CLEAN, all the connectors and everything are perfectly fine! Sold!
***Front Upper and Lower control arm set + Tie rod ends! (11/8/06)*** New Poly. bushings in both upper and lower control arms + new OEM ball joints and includes new OEM tie rod ends! These parts have about 1-2k miles on them, they're practically BRAND new. $120 for everything! Paid over 200 for the whole setup.
**Buyer Dropped Out, now available (9/27/06)**-CRX Driver's side Door, NEW from Honda, hasn't even been on the car for a year! RETAIL cost is $550 + tax for the door and it's BARE, doesn't come with anything! This door includes all moldings including the one that goes against the glass to keep rain out. The inner weather strips are also brand new oem pieces. It has glass, regulator, and crank handle as well. It's only missing the side mirror, and center trim piece! $250
**(9/27/06) OBD0 MPFI Distributor!** Forgot to list this up! Remanned OEM distributor! This is what I had on my 88 Si stock motor until I did the mini-me swap, only has 1-2k miles on it, paid $175 for it, just looking for $75! Worked perfect when I pulled it off the head! Sold!
**(9/27/06) PM6 D16a6 CRX/Civic Si Stock/Virgin ECU!** Sold!
-Windshield with no cracks! Sold!
-CRX Si rear hatch complete with glass, wiper arm and motor. Sold!
-OEM washer bottle + sprayer motors. Sold!
-CRX Si rear swaybar + endlinks $20
-1/4 window interior trim pieces - Sold!
-Wiper Arms - Sold!
-D16a6 intake manifold complete minus injectors. Sold!
-I also have two rear cabinets that sit behind the front seats, $20 a piece. Sold!
-Brand new black carpet! Never installed, paid 200 + shipping for this thing, looking to get $150!
Modified by DC5Tuner at 4:03 PM 1/26/2007
Modified by DC5Tuner at 11:30 PM 2/10/2007
Modified by DC5Tuner at 11:34 PM 5/5/2007
Old Jan 24, 2007 | 12:16 PM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (DC5Tuner)
Bump!
Old Jan 24, 2007 | 08:58 PM
DC5Tuner's Avatar
TTT!
Old Jan 24, 2007 | 09:23 PM
boost89hatch's Avatar
do you have the Engine Harness and if you do how much
Old Jan 25, 2007 | 02:35 PM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (boost89hatch)
Engine Harness is sold...everything that is sold is marked!
Old Jan 25, 2007 | 08:10 PM
svacca1's Avatar
so the seats are 150 for both? Do you ship?
Old Jan 26, 2007 | 03:03 PM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (svacca1)
^ IM'ed
Old Jan 26, 2007 | 03:04 PM
DC5Tuner's Avatar
Fog Light Switch = Sold!
Old Jan 28, 2007 | 07:19 PM
DC5Tuner's Avatar
Bump!
Old Jan 29, 2007 | 09:04 AM
fsteclipsegst01's Avatar
i got dibs on the amber bumper lights. is it 20 shipped?
Old Jan 29, 2007 | 04:41 PM
94b16teg's Avatar
I need all 3 wiper arms and and passenger side mirror. Do you have a rustfree sunroof panel?
Old Jan 30, 2007 | 08:46 AM
89efDUSTY's Avatar
Damn thats a part out...bump
Old Jan 30, 2007 | 07:19 PM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (89efDUSTY)
Replied to everyone via IM's.
Thanks for the bump!
Old Jan 30, 2007 | 08:21 PM
TodaCivic's Avatar
You got PM.
Old Jan 31, 2007 | 10:15 AM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (TodaCivic)
^ Replied.
Old Feb 1, 2007 | 03:43 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Do you have the hatch struts? (Gas struts)? How much to 19422? (Need to be in working/good order... if they are weak let me know!)
Old Feb 1, 2007 | 08:48 AM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (phoenix_iii)
^ IM'ed.
Old Feb 3, 2007 | 07:59 AM
BacardiBreezer's Avatar
Hey for number 11, the bumper lenses, is that price shipped?
Old Feb 3, 2007 | 10:02 PM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (BacardiBreezer)
^ IM'ed.
Old Feb 4, 2007 | 06:25 AM
90nhcrxsi's Avatar
I am looking for oem headlights and the drivers side fender splash guard and b-pillar covers
Old Feb 4, 2007 | 11:39 AM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (90nhcrxsi)
^ IM'ed.
Old Feb 4, 2007 | 04:06 PM
NEVER RECEIVED AN IM.
Old Feb 4, 2007 | 07:41 PM
DC5Tuner's Avatar
Yeah you did, you must not have good memory...here is a copy of it!
(9:47 AM 2/1/2007) DC5Tuner: I have the struts and they're practically brand new, were only on the car for a few months! Only thing is they're under pending sale. If the buyer drops out though I'll let you know.
(9:51 AM 2/1/2007) phoenix_iii: Cool thanks. Let me know what happens.
Anyways, the guy who's supposed to be buying them hasn't gotten back to me in a while so they're available again. I can do $60 shipped for them. Also I do not have a paypal acount...I can only accept money orders.
Let me know,
Thanks
-John
Old Feb 5, 2007 | 06:13 AM
bmg123's Avatar
pmd
Old Feb 5, 2007 | 09:35 AM
DC5Tuner's Avatar
Default Re: Parting out my CRX! (bmg123)
^ Replied.
