99/00 Si full brake conversion on an eh2...additional parts?
Old Jan 22, 2007 | 07:51 PM
CivicVX94's Avatar
Default 99/00 Si full brake conversion on an eh2...additional parts?
I'm getting a COMPLETE brake conversion, front and rears along with all lines and cables, off of a 99/00 si. i will be putting this on a 94 civic vx hatch.
what additional parts will i need for this to work? i think i'll need integra lower control arms for the rear, but what about the front?
i'm also going to get a stainless steel brake line kit before i put this on too, would i order it for a 99/00 si or a 92-95si b/c its the same chassis and also had rear discs...
I searched but everything is mainly for just rear disc conversion or a full integra brake conversion.
Any help will be appreciated. THanks in advance.
Old Jan 22, 2007 | 07:53 PM
ekb16's Avatar
i think u would need a new pro. valve and a diff M/C
Old Jan 22, 2007 | 08:05 PM
CivicVX94's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">i think u would need a new pro. valve and a diff M/C</TD></TR></TABLE>
ya thats covered. i just need to know how to get it to bolt up.
Thanks for the response
Old Jan 22, 2007 | 08:19 PM
ekb16's Avatar
well then this link should help you out
under SUSPENSION
https://honda-tech.com/zerothread/642479
Old Jan 22, 2007 | 08:22 PM
CivicVX94's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">well then this link should help you out
under SUSPENSION
https://honda-tech.com/zerothread/642479</TD></TR></TABLE>
ya that was the first place i looked. most everything there is either strictly rear disc conversion or a full integra brake conversion.
i found somewhere that with si rear discs you need integra lower conrol arms...but that's just the rear, i need to know about the front also and would like that to get confirmed.
Thanks for your help
Old Jan 22, 2007 | 11:38 PM
BlueIntegraBoy's Avatar
Default Re: 99/00 Si full brake conversion on an eh2...additional parts? (CivicVX94)
If you have the whole trailing arm with brakes and the whole knuckle with brakes, that's all you need. You don't need the LCAs front or rear.
Make sure you get the brake lines and ebrake cables. Get a 4040 prop valve from a 90-93 Integra non-ABS or 94-95 Integra RS. Buy a master cylinder from a 1991 Civic EX or master cylinder with brake booster from a 94-95 Integra RS.
Old Jan 23, 2007 | 09:11 AM
CivicVX94's Avatar
Default Re: 99/00 Si full brake conversion on an eh2...additional parts? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">If you have the whole trailing arm with brakes and the whole knuckle with brakes, that's all you need. You don't need the LCAs front or rear.
Make sure you get the brake lines and ebrake cables. Get a 4040 prop valve from a 90-93 Integra non-ABS or 94-95 Integra RS. Buy a master cylinder from a 1991 Civic EX or master cylinder with brake booster from a 94-95 Integra RS.</TD></TR></TABLE>
Are you POSITIVE about all of that?If so, thanks alot man
can i not use the prop valve or master cylinder off the si?
Old Jan 23, 2007 | 09:36 AM
EL Vap133's Avatar
For the fronts, use your STOCK Upper Control Arms.
Old Jan 23, 2007 | 09:48 AM
CivicVX94's Avatar
Default Re: 99/00 Si full brake conversion on an eh2...additional parts? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">For the fronts, use your STOCK Upper Control Arms. </TD></TR></TABLE>
cool and everything else up there bolts up fine?
And for the rear, do i use my stock LCA's or Si LCA's?
Thanks for all the help
Old Jan 23, 2007 | 11:09 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for all the help </TD></TR></TABLE>
Use your stock LCAs.
Old Jan 23, 2007 | 06:17 PM
CivicVX94's Avatar
Use your stock LCAs. </TD></TR></TABLE>
Great, thanks a lot
Andy099
May 14, 2006 06:14 PM
honda_coupe
Sep 28, 2005 06:57 PM
integra pride
Aug 10, 2005 09:35 PM
Lil Red CRXsi
Feb 18, 2005 01:38 PM
96BlackHB
Feb 10, 2004 05:06 PM
