My b20vtec dyno...hows it look?
Old Jan 22, 2007 | 07:22 PM
Mag00n's Avatar
Default My b20vtec dyno...hows it look?
Just got my car tuned, pretty happy with the results, although i was really hoping for 220+, but my injectors were just about maxed out, and every dyno is different, so i cant really complain...tell me what you think
setup
b20b/gsr head
12:5:1
RMF Header
crower cams
skunk2 IM
k&n on a stick
3" exhaust
before
base
tuning
215/146
Old Jan 22, 2007 | 07:25 PM
goforbroke's Avatar
MEAT PATTY
Default Re: My b20vtec dyno...hows it look? (.m a c a)
Where did you get it tuned? Good numbers.
Old Jan 22, 2007 | 07:30 PM
Mag00n's Avatar
Default Re: My b20vtec dyno...hows it look? (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">Where did you get it tuned? Good numbers. </TD></TR></TABLE>
synapse motosports
Runnerdown's Avatar
It did pretty good...however we would have liked to adjust the cam gears and have bigger injectors to dial it in a little better.
Old Jan 22, 2007 | 07:33 PM
Mag00n's Avatar
Default Re: My b20vtec dyno...hows it look? (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">It did pretty good...however we would have liked to adjust the cam gears and have bigger injectors to dial it in a little better. </TD></TR></TABLE>
thanks for chiming in man...definately looking into bigger injectors, probably dsm 390's
Old Jan 22, 2007 | 08:59 PM
EG6R's Avatar
What size of injectors are you using now?
Old Jan 22, 2007 | 09:21 PM
Mag00n's Avatar
Default Re: My b20vtec dyno...hows it look? (EG6R)
they are supposed to be prelude 345's but we are suspect because i doubt 345's would run out of steam on this setup....im not sure if theres a way to tell for sure...
Old Jan 22, 2007 | 10:14 PM
vivid 02's Avatar
Looking good. Try the JGedelbrock intake manifold and a 68 mm tb.
That helped me out.
Old Jan 22, 2007 | 11:05 PM
esohsee's Avatar
Default Re: My b20vtec dyno...hows it look? (vivid 02)
nice numbers. you should just get 440 injectors.
Old Jan 23, 2007 | 06:02 AM
Synapse Motorsport's Avatar
Default Re: My b20vtec dyno...hows it look? (esohsee)
The 1st graph wasn't a base, it made very little power as the map started from scratch. We hit 210 then ran out of feul, with some bigger injectors, some more tuning and tuning cam gears, I see 220whp in its future.
Old Jan 23, 2007 | 08:22 AM
Rollo Lawson's Avatar
which Crowers did you run?
racin jasin R
May 2, 2007 01:05 PM
ChicagoMike
21
Jan 20, 2006 06:51 AM
myhatchrips
Feb 9, 2004 07:18 PM
andrewM
Jul 22, 2003 11:30 AM
JBk24crx
Jun 6, 2003 05:32 PM
