fuel pressure to high
Old May 16, 2002 | 08:43 AM
lilcasino's Avatar
Default fuel pressure to high
Right now my fuel pressure is set at 52 (vaccum off and pinched) is that high for a 98' gsr with i/h/e? The reason I ask is sometimes the car starts hard, and only has starting doing this after installing my AEM FPR.
Old May 16, 2002 | 08:49 AM
fastludeh22's Avatar
Default Re: fuel pressure to high (lilcasino)
ya, thats too high. not sure what is a good psi for a gsr cause i have a lude, but contrary to poupler thoughts with i/h/e u dont want to raise psi, if u look at people w/v-afc and simliar devices they act. lean it out to get power. if u have an a/f gage it makes it easier, but if not try turning it down and see how this feels, then check your plugs to make sure your not lean, then repeat till it feels the strongest and your plugs arent white, a sign of running lean.
btw- go ahead and check ur plugs now, if they are black thats a sign of running heavily rich. u are supposed to turn the car off at wot to check plugs, but i dont know how important it is to do that.
Old May 17, 2002 | 04:23 AM
lilcasino's Avatar
Default Re: fuel pressure to high (93ludevtec)
anyone else?
Old May 17, 2002 | 06:20 AM
96IntegraRS's Avatar
What other stuff do you have?
Increasing pressure is usually a forced induction related thing...
Old May 17, 2002 | 11:13 AM
lilcasino's Avatar
Default Re: fuel pressure to high (96IntegraRS)
Just AEM CAI, Apex N1, JDM Header with carsound cat, no ps, converted to obd1, and vafc.
Old May 17, 2002 | 12:53 PM
Mr. Softee's Avatar
mines at like 50 with the line on... and i have jun3s and 12:1 compression... and i have to lean it out 20% at idle.
to answer your question: yes thast way too high.
Old May 17, 2002 | 03:13 PM
lilcasino's Avatar
Default Re: fuel pressure to high (94goldjungsr)
Mine with the line on is 42 with line off and pinched its 52. I dont think that is the problem, this is what I noticed when put the key on and turned if over to acc. The fuel pump started and the fuel pressure when to 40, but then it started to drop, down to 0. Is that normal? If not now whats the problem...the only thing that is installed for fuel is a pressure gauge and the aem fpr.
RedRacerCivic
Oct 29, 2004 06:30 AM
srehmat02
Oct 15, 2004 07:13 PM
Vtecfool
Mar 1, 2004 11:04 PM
93preludeh22
Sep 23, 2003 03:38 PM
95integrags-r
May 9, 2002 02:14 PM
