How much would a shop charge to fix a leaked rear balance shaft seal on a 97 SH?
Old Jan 22, 2007 | 06:53 PM
justint's Avatar
Default How much would a shop charge to fix a leak in the rear balance shaft seal on a 97 SH?
My mechanic says that the rear balance shaft seal (not the front one that pops off all the time) on my 97 SH is the cause of my fairly significant oil leak. Is this a difficult fix? Does the engine need to be pulled?
Old Jan 23, 2007 | 04:01 AM
flyrod's Avatar
Default Re: How much would a shop charge to fix a leak in the rear balance shaft seal on a 97 SH? (justint)
It should cost about the same as replacing a water pump.
Old Jan 23, 2007 | 08:05 AM
kulrevon's Avatar
Default Re: How much would a shop charge to fix a leak in the rear balance shaft seal on a 97 SH? (flyrod)
I do believe its the front one that falls off all the time. I just fixed mine.
The problem is that the leak then leaks oil on your timing belt. and once you get oil on the rubber it can expand and break.
If they do the timing belt and everything It might cost upwards or $500.
Old Jan 23, 2007 | 11:48 AM
ricedadee's Avatar
not as much if you diy it.
Edit:
How sure is he about the rear balancer seal..
Modified by ricedadee at 1:22 PM 1/23/2007
Old Jan 23, 2007 | 01:46 PM
BB2H22's Avatar
Why not call a shop?
If you ever pull the motor, just elimate the balance shafts.
Old Jan 23, 2007 | 02:32 PM
lude27's Avatar
Yea last time i ran at the track i blew my balancer shaft seal, crankshaft seal, and the oil got all over the timing and balancer shaft belts.. it ran me about $550 to replace everything. needless to say i lost all of my oil in about 15 minutes.
Old Jan 23, 2007 | 03:49 PM
justint's Avatar
Default Re: How much would a shop charge to fix a leak in the rear balance shaft seal on a 97 SH? (ricedadee
I didn't actually see the leak, but the shop that just changed out my crank pulley and accessory belts indicated that was where the leak was from. Would the reat balancer shaft seal be leaking on my timing belts.
Old Jan 23, 2007 | 05:09 PM
justint's Avatar
If the oil from this type of leak won't get all over my belts, I might just keep an eye on the oil level and wait for my next timing belt change to get this resolved. I just had the timiing belt etc. done about 12k ago.
Old Jan 24, 2007 | 04:26 AM
kulrevon's Avatar
Yes the balancer belt seal will leak oil onto the belts (balancer and timing).
Old Jan 27, 2007 | 12:19 PM
ricedadee's Avatar
Default Diy
I don't think you will know by checking the oil level..
I would only say you should visually check the belts but, how.
I wish honda would make a clear valve cover so we don't have to take apart the valve cover
xtcrevive
Jul 6, 2015 01:33 AM
Ajsbored
Apr 14, 2014 06:59 PM
rulvis
Dec 21, 2008 06:29 PM
gamblezhang
Dec 5, 2008 06:50 PM
Chiovnidca
Jan 3, 2003 10:28 AM
