how many pounds can i run on this set up safely
Old Jan 22, 2007 | 05:05 PM
donvito#1's Avatar
Default how many pounds can i run on this set up safely
Engine:stock jdm B18B, xspower manifold, airesearch T3, turbonetics evolution WG, johnny racecar fmic, HKS SSQ BOV, DSM 450 injectors, high flow inline pump, MSD blaster coil, MSD cap and rotor, chipped ecu with crome engine management, running 7 psi. just want to no if im under boosting
Old Jan 22, 2007 | 05:14 PM
doood's Avatar
been there done that
Default Re: how many pounds can i run on this set up safely (donvito#1)
psi does not matter. you can make 250whp safely if tuned well.
goodluck with that manifold.
Old Jan 22, 2007 | 05:30 PM
jfoster's Avatar
Default Re: how many pounds can i run on this set up safely (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">psi does not matter. you can make 250whp safely <U>if tuned well</U>.
goodluck with that manifold.</TD></TR></TABLE>
Its all in your tuning/tuner. Also depends on what you consider safe ... personally if I can squeeze 300whp out of my LS and make it last 30k miles of abuse I'll be pleased ... but if you're wanting like 100k+ more miles out of your motor then around 7psi and around 230whp from a reputable tuner would be most peoples opinion of safe/conservative.
Old Jan 22, 2007 | 06:56 PM
donvito#1's Avatar
Default Re: how many pounds can i run on this set up safely (jfoster)
the motor has only 60k
Old Jan 22, 2007 | 07:00 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donvito#1 &raquo;</TD></TR><TR><TD CLASS="quote">the motor has only 60k</TD></TR></TABLE>
compression test results?
kilerintegra
Engine Management and Tuning
14
Nov 3, 2010 10:15 PM
JDM CALI STYL3
13
Aug 19, 2007 09:22 AM
donvito#1
Jan 22, 2007 07:46 PM
love2xlr8integra
Jun 24, 2004 06:32 AM
WangChung
Nov 7, 2003 04:49 AM
