im having problem w/ my idle air control valve
Old May 16, 2002 | 07:58 AM
jdm civic 2000's Avatar
Default im having problem w/ my idle air control valve
i just swaped in a b16b r motor in my 2000 civic dx,shes runnin good but the idle is jumping,and the code from the ecu(93) is 14,which is the "iac valve",im using my 2000dx wiring harness and i had to rewire a plug to fit on the iac valve so when i went to do that ,i noticed that there are 3 wires from the dx harness,and the "iac: needs 2,so i need info on what to do to get it to work,ive already tested the "iac"and it works ,but i need info on how to convert 3 wires into 2 wires or directly run a wire to the ecu,and if so,what pin #(93 ecuw/ jumper harness,to fit 2000dx plugs of harness)any help or advise is greatful,but experties is a must
Old May 21, 2002 | 06:08 PM
Default Re: im having problem w/ my idle air control valve (jdm civic 2000)
anyone got any ideas?
jdmcrx_echelon
Aug 29, 2006 12:33 AM
crnimacak
Feb 22, 2006 11:56 PM
marcaobr
Nov 16, 2005 08:09 PM
jdm civic 2000
Aug 27, 2004 05:31 PM
jdm civic 2000
May 21, 2002 08:41 PM
