going to check my compression
Old Jan 22, 2007 | 03:35 PM
jwteg23's Avatar
Default going to check my compression
so i dont really think my 94gsr with i/h/e pulls like a normal gsr i got beside a stock gsr on the interstate and he pulled me hard also a b16 w/gsr cams pulled me like a bitch i think my compression may be low what do you guys think no codes or anything but do need mounts do you think this can affect it that much what can i do to fix the compression do i need new pistons and rods/rings or what any help would sure be thankful
Old Jan 22, 2007 | 04:04 PM
Fat Chick Magnet's Avatar
take off your cat.
how many miles does your car have? and run compression test.
Old Jan 22, 2007 | 06:39 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwteg23 &raquo;</TD></TR><TR><TD CLASS="quote"> what can i do to fix the compression do i need new pistons and rods/rings or what any help would sure be thankful</TD></TR></TABLE>
Dont start rebuilding your motor because you got beat. Check your compression first and see whats up. Also do a leak down test if you can, that will also help. Post your results and get back with us.
Old Jan 22, 2007 | 07:33 PM
95 integra's Avatar
Default Re: (SlammedDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Dont start rebuilding your motor because you got beat. Check your compression first and see whats up. Also do a leak down test if you can, that will also help. Post your results and get back with us.</TD></TR></TABLE>
Or maybe its the cheap mods and if you put your OEM parts back on you'd make more power.
Old Jan 22, 2007 | 09:48 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">
Or maybe its the cheap mods and if you put your OEM parts back on you'd make more power.</TD></TR></TABLE>
I was thinking that, but figured at least get the compression and leak down results first before making any conclusions.
Old Jan 28, 2007 | 06:08 AM
1sikhatch's Avatar
im in the same situation, my gsr has the normal bolt ons and its slow like hell so i did a compression test and i got 160 psi on eah cylinder and the manual says 270 psi on each so im changing my rings and pistons this week.
Old Jan 28, 2007 | 10:17 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (1sikhatch)
160 is low, what pistons are you going with?
Old Jan 28, 2007 | 11:08 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">im in the same situation, my gsr has the normal bolt ons and its slow like hell so i did a compression test and i got 160 psi on eah cylinder and the manual says 270 psi on each so im changing my rings and pistons this week.</TD></TR></TABLE>
Remember that the compression gauge has a significant influence on the magnitude of the compression, where a larger dead space in the gage will yield a lower compression. Also, did you have the throttle at WOT and was the engine fully warm?
Old Jan 28, 2007 | 03:28 PM
1sikhatch's Avatar
Default Re: (Dogginator)
yes i did it both with the cold motor and warm at wot. im goin with jdm ITR pistons and stock rods for now. btw whats the break in period for new rings?
pettyboy69
Jun 22, 2009 07:39 AM
CivicSH
Oct 4, 2007 09:48 PM
Dev15Bizz
May 2, 2007 08:19 PM
vtec25
Aug 20, 2006 12:28 AM
