Which brand sway bar?
I'm pretty new to this so I've got to ask. Recently I just picked up a SKUNK2 front upper strut, rear upper strut and lower tie bar for my 95 4dr GSR. My homie told me that I should get some sway bars because those help with handling WAY more then the struts. I'm looking for a good affordable brand that has good quality at a low cost. If you guys could help me with this that would be great. Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">Look into getting the Type R rear sway bar. Its larger in diameter in comparison to the GSR.</TD></TR></TABLE>
Make sure you get the bsq or beaks or asr subframe brace as well.
What Brand? Honda, LOL. Yeah get OEM ITR rear sway. USDM at 22 or JDM at 23. USDM will be about 80, JDM will be about 100. Then you need the "D" brackets and bushings, either OEM or ES. That's another 20 I think. And the BSQ kit for another 20 or the Beaks kit for about 60, if I remember correctly. Either way, it'll be the best $140-$200 you've ever spent on handling of your car.
If you wanted to go real hard core with an adjustable sway bar, I think Neuspeed makes an adjustiable for about $250. Just depends on what you want and how much $$$ you want to spend. The USDM OEM 22 will give a pretty neutral feel; some have stated that the JDM 23 will give a slight oversteer bias. But that's second hand information. I have a USDM OEM 22 rear and OEM "LS" 22 front and it has a very neutral feel for me.
ITR rear with bsq subframe kit.
From http://www.team-integra.net/se...D=692
Parts needed for the install:
01. 52300-ST7-Z01 rear sway bar – Quantity: (1)
02. 52315-ST7-Z01 sway bar bushing – Quantity: (2)
03. 52308-SS0-000 bushing bracket – Quantity: (2)
04. 52316-ST7-Z00 end link bushing – Quantity: (2)
05. 52312-ST7-Z00 end link bushing collar – Quantity: (4) – can be reused from the stock sway bar but recommended to get new ones.
06. 90175-ST7-Z00 bolt (8x35) – Quantity: (2)
07. 94050-08080 flange nut (8mm) - Quantity: (2)
I ordered from http://www.barancoacuraparts.c...e.jsp
and
http://www.geocities.com/bretq/mounting_kit.html
and
I have a suspension techniques (spelling?) 19mm rear sway bar, and I am going to be moving up to either a 22 or 23mm oem honda one. I would like my teg to be a little more nuetral in the corners, and hopefully this will help. Also, I am going to be adding blox adjustable endlinks to toy around with also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 »</TD></TR><TR><TD CLASS="quote">I am going to be picking up an ITR 23mm and ASR subframe brace.</TD></TR></TABLE>
i would recommend this setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnut »</TD></TR><TR><TD CLASS="quote">what about the front sway bars?</TD></TR></TABLE>
leave alone.
leave alone.
