need help fast. changing belts
ok so i have a 93 accord that i am changin the belts in. i loosened the alternator to let that belt loose, but then cut the alternator belt prior to loosening it. so i then unbolted the alt. from the top and thought that would allow it to drop enough to slide on the belt, NOPE. what do i need to do to get this thing on. please help quick. it is getting dark outside in a couple of hours and i need a car for tomorrow. thanks guys
cade
cade
The Alt has a bottom nut 12mm, that needs to be loosened up, then under the front side of the ALT there is a long 10mm bolt that runs up the tension.
the upper 14mm bolt is the pivot point
I've got a pic somewhere; I'll repost if I find it
SouthflSaint
Aug 12, 2010 10:28 AM
