Help me save some money, Tranny prob
Old Jan 22, 2007 | 06:20 AM
Shawn Till Dawn's Avatar
Default Help me save some money, Tranny prob
92 accord auto trans. Well I was accelerating on a on ramp to the h-way and the car jerked then when i gassed the pedel only RPMS went up but nothin as far as going forward. Coasted off the H-way and the car would still idle forward but nothing when pedel depressed. Pulled into a parkin spot and shut the car off. Tried to restart but it wouldn't. Only the whine of the starter. Not sure what to do, had to drop 100 for the tow and they want 75 for a tow and 75 for the inspection at the repair shop, just to tell me what is to be fixed. Thanks
Old Jan 22, 2007 | 06:27 AM
Patman's Avatar
AAAplus anybody? Try using 1st 2nd and seeing if it moves. If not I'd skip the auto BS and start pricing parts for a 5spd swap.
Old Jan 22, 2007 | 06:33 AM
Default Re: (Patman)
Do you mean push the car while in 1st or 2nd and if it moves then It's a gonner? I'll try it.
Old Jan 22, 2007 | 06:53 AM
Default Re: (Shawn Till Dawn)
Well I went out the car put it in all the different gears (automatic trann) and pushed it back and forth the car did move when pushed in all the gears, excluding park....... Does that mean anything?
Old Jan 22, 2007 | 06:59 AM
hondadude's Avatar
maybe an inner CV joint popped out of the differential?? Hope Hope Hope LOL
Old Jan 22, 2007 | 07:03 AM
Default Re: (hondadude)
well i guess i will probably just have to tow it to the shop, just hate to spend all the money. for a $1500 car.
Old Jan 22, 2007 | 07:45 AM
Homesickelian's Avatar
The car made no grinding noise when it popped out?
Old Jan 22, 2007 | 12:26 PM
Default Re: (Homesickelian)
I did'nt hear any grinding.
Old Jan 22, 2007 | 04:44 PM
JDM_DC4_Fanatic's Avatar
Default Re: Help me save some money, Tranny prob (Shawn Till Dawn)
check your fluid levels. If the fluid is brown, change it and change the filter. i'd start praying that there is no torque converter damage, and its just low fluid.
Old Jan 22, 2007 | 05:19 PM
Patman's Avatar
Interesting idea Fana, do they have a "refuse to work" mode like engines when fluid is so low? I meant see if the 1-3 gears work while driving to see if its a specific gear.
Old Jan 22, 2007 | 05:22 PM
raceACCORDingly's Avatar
get under and check the axle
Old Jan 23, 2007 | 07:57 PM
Chaos3252006's Avatar
Check your axles.
Check to see if your torque converter is turning.
If it wont start and the starter is whining it sounds like the torque converter.
dominate9
Sep 3, 2007 02:00 PM
Siegfried
Feb 13, 2006 07:35 PM
HONDA92HATCH
Oct 27, 2005 07:42 AM
na96gsr
Sep 30, 2004 01:33 AM
BoostedSi
Sep 13, 2003 08:39 PM
