Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Octane: Interesting article!
Old Jan 21, 2007 | 11:13 PM
jonssonar's Avatar
Default Octane: Interesting article!
Now I know for SURE that i'm wasting money when I put in plus/premium into my R18.
http://www.sciam.com/article.c...C1D4F
Old Jan 21, 2007 | 11:50 PM
Nohawk's Avatar
Default Re: Octane: Interesting article! (jonssonar)
Thanks for sharing this article.
Old Jan 22, 2007 | 02:29 AM
RICO_'s Avatar
NO MERCY!
Default Re: Octane: Interesting article! (Si 4 Life)
Taken from the article......
"First and foremost, premium gas really is a better fuel in terms of the power it provides in the right engine."
That's the key sentence in the entire article. Interesting stuff. Thanx for sharing.!
Old Jan 22, 2007 | 08:38 AM
jonssonar's Avatar
Default Re: Octane: Interesting article! (RICO_)
I thought the main point of the article was,
"The regular fuel will burn properly and the premium fuel will burn properly and therefore there is no reason you should pay the extra money" (R18)
... unless the engine's compression ratio was designed for the higher octane. (K20)
Old Jan 22, 2007 | 05:24 PM
mInI m3 Hondeezy's Avatar
Well cmon u should have know this they dont just put those sticker on the gas cap for nothing.
Old Jan 22, 2007 | 05:28 PM
Mediademics's Avatar
Default Re: (mInI m3)
I think the point this article makes to R18 owners is that putting in premium vs. regular is not doing you any more justice, and to just use regular as your car doesn't require any higher.
Si owners know that they need premium and this article tells them nothing.
I understood this just fine, thank you for sharing the article
Old Jan 22, 2007 | 06:12 PM
HondaF1Fanatic's Avatar
Isn't the ECU adaptive enough on the R18 to at least advance timing a bit and give you a bit more power?
Jon
Old Jan 22, 2007 | 06:40 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
yep yep had to bold that part out
Old Jan 22, 2007 | 06:45 PM
nsxmatt's Avatar
Default Re: (HondaF1Fanatic)
If the ecu detects knock with 87 and retards timing then you shoudl run a higher octane. Without driving with a HDS hooked up under load you will never know.
Honda tells you what gas to use with the car, listen to them.
Old Jan 25, 2007 | 10:29 AM
xtant21's Avatar
"High-performance engines, such as those in some sports cars or older, heavier automobiles, often boast much higher compression ratios."
"... unless the engine's compression ratio was designed for the higher octane. (K20)"
Not that the R18 will ever be mistaken for the K20 but 10.5:1 isn't too far off from 11:1. Now, if we were talking about the run-of-the-mill compression ratios...this is very true. Octane is always a relative term to the person putting it in the tank but if we are simply stating that Premium is better for higher compression engines...then the R18 should be able to see some sort of benefit albeit minor...so we are still at the point...if you want to pay for it...use it...if not don't (R18 that is).
Old Jan 25, 2007 | 01:19 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaF1Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">Isn't the ECU adaptive enough on the R18 to at least advance timing a bit and give you a bit more power?
Jon</TD></TR></TABLE>
You would think so, but it doesnt.
SlowEJ8
48
May 2, 2009 06:44 AM
Donkey85
May 9, 2008 08:30 PM
99hondacura
Jul 30, 2006 03:09 AM
Captain Flaps
Feb 6, 2006 07:22 AM
FlipboiGSR
Sep 4, 2001 08:23 AM
